[GeoNetwork-devel] [GeoNetwork opensource Developer website] #775: Uploaded Plugin Profile does not work
Reporter: heikki | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: blocker | Milestone: v2.7.0
Component: General | Version:
Keywords: plugin profiles |
I have a Plugin Profile that works fine if I manually put it in
web/geonetwork/xml/schemas before starting GeoNetwork.
But it doesn't work when you upload it:
  * I made a zip file of it and uploaded that; it got unzipped in
web/geonetwork/schemaPlugins
  * the profile was listed in the admin page, where I could successfully
load the templates from my profile
  * going to New Metadata, the names of the templates of this profile are
not displayed (Ext GUI);
  * selecting one and trying to create a metadata from it fails, because it
tries to load XSLTs from its base ISO19139 schema from the
web/geonetwork/schemaPlugins directory (where they aren't) instead of from
the web/geonetwork/xml/schemas directory:
Error at xsl:include on line 7 column 57 of update-fixed-info.xsl:
   XTSE0165: java.io.FileNotFoundException:
   /web/geonetwork/schemaPlugins/iso19139/convert/functions.xsl (The system
cannot find the path specified)
  * schemaplugin-uri-catalog.xml *was* updated with lines like
   <uri name="blanks/metadata-schema07.xsl"
uri="../xml/schemas/iso19139.myprofile/present/metadata-
iso19139.myprofile.xsl" />
   <uri name="blanks/metadata-schema07-edit.xsl"
uri="../xml/schemas/iso19139.myprofile/present/metadata-iso19139
.myprofile-edit.xsl" />
  * finally I tried manually moving the profile directory from
web/geonetwork/schemaPlugins to web/geonetwork/xml/schemas, and restart.
Now the home page doesn't show up anymore because it is looking for my
profile in web/geonetwork/schemaPlugins:
Error at xsl:include on line 12 column 52 of metadata-utils.xsl:
   /web/geonetwork/schemaPlugins/iso19139.myprofile/present/metadata-
iso19139.myprofile.xsl (The system cannot find the path specified)
So to summarize, it seems there is some confusion when a Plugin Profile is
uploaded as to whether it is or should be in web/geonetwork/xml/schemas or
in web/geonetwork/schemaPlugins.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/775&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: plugin profiles schema |
Changes (by sha):
  * keywords: plugin profiles => plugin profiles schema
Comment:
'''Tried''' : I tried the same, but with the example files I downloaded
with the schemaPlugin. I tried the schema iso19139.mcp-1.4 and
iso19139.anzlic. The result for both of the example schemes are the same
as described by heikki.
Before uploading a schema, GeoNetwork "works". After uploading a schema,
GeoNetwork doesn't do anything any more, except showing the error on every
page, not only the admin page.
'''Noticed''' : I also took a look on the location of the uploaded schema.
In my case (I run the geonetwork.war under tomcat), this seems to be:
/usr/share/tomcat6/webapps/geonetwork/usr/share/tomcat6/webapps/geonetwork
/WEB-INF/data/config/schema_plugins/iso19139.mcp-1.4
Which is awkward (the part of the usr/share/tomcat6/webapp/geonetwork path
is double!).
'''Undo''' : To get geonetwork working again, I have to delete the whole
geonetwork dir under tomcat and redeploy the war (thus throwing away all
data caused by the upload of the schema).
'''Exception''' : Here I put the exception from the geonetwork.log. It
seems it isn't looking at the place where the schema has been put (see the
awkward path above) and, there seems to be a slash missing in the path, I
see "schema_pluginsiso19139.mcp-1.4" in the path in the logging.
2012-03-30 13:26:55,987 INFO [jeeves.service] - Dispatching : main.home
2012-03-30 13:26:55,987 DEBUG [jeeves.service] - -> no input parameters
2012-03-30 13:26:55,987 INFO [jeeves.service] - -> dispatching to
output for : main.home
2012-03-30 13:26:55,996 ERROR [jeeves.webapp.main.home] - Failed to load
guiservices for schema iso19139.mcp-1.
4: /usr/share/tomcat6/webapps/geonetwork/WEB-
INF/data/config/schema_pluginsiso19139.mcp-1.4/loc/eng/codelists.x
ml (No such file or directory)
2012-03-30 13:26:56,056 INFO [jeeves.service] - -> transforming with
stylesheet : /usr/share/tomcat6/weba
pps/geonetwork/xsl/main-page.xsl
2012-03-30 13:26:56,452 ERROR [jeeves.service] - -> exception during
transformation for : main.home
2012-03-30 13:26:56,452 ERROR [jeeves.service] - -> (C) stylesheet :
xsl/main-page.xsl
2012-03-30 13:26:56,453 ERROR [jeeves.service] - -> (C) message :
Failed to compile stylesheet. 3 errors detected.
2012-03-30 13:26:56,453 ERROR [jeeves.service] - -> (C) exception :
TransformerConfigurationException
2012-03-30 13:26:56,453 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
   <message>Failed to compile stylesheet. 3 errors detected.</message>
   <class>TransformerConfigurationException</class>
   <stack>
     <at class="net.sf.saxon.PreparedStylesheet"
file="PreparedStylesheet.java" line="176" method="prepare" />
     <at class="net.sf.saxon.TransformerFactoryImpl"
file="TransformerFactoryImpl.java" line="139" method="newTemplates" />
     <at class="de.fzi.dbs.xml.transform.CachingTransformerFactory"
file="CachingTransformerFactory.java" line="127" method="newTransformer"
file="CachingTransformerFactory.java" line="82" method="newTransformer" />
     <at class="jeeves.utils.Xml" file="Xml.java" line="467"
method="transform" />
     <at class="jeeves.utils.Xml" file="Xml.java" line="393"
     <at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="721" method="dispatchOutput" />
file="ServiceManager.java" line="417" method="dispatch" />
     <at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="723" method="dispatch" />
     <at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="198" method="execute" />
file="JeevesServlet.java" line="102" method="doGet" />
     <skip>...</skip>
   </stack>
   <request>
     <language>eng</language>
     <service>main.home</service>
   </request>
   <response />
</error>
2012-03-30 13:26:56,453 INFO [jeeves.service] - -> dispatching to
error for : main.home
2012-03-30 13:26:56,461 ERROR [jeeves.webapp.main.home] - Failed to load
guiservices for schema iso19139.mcp-1.4:
INF/data/config/schema_pluginsiso19139.mcp-1.4/loc/eng/codelists.xml (No
2012-03-30 13:26:56,463 INFO [jeeves.service] - -> transforming with
stylesheet : /usr/share/tomcat6/webapps/geonetwork/xsl/error.xsl
2012-03-30 13:26:56,494 INFO [jeeves.service] - -> end error
2012-03-30 13:26:56,494 INFO [jeeves.service] - -> error ended for :
main.home
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/775#comment:1&gt;
Comment(by sha):
I referred to heikii for the error, but I meant taniapf on http://osgeo-
org.1560.n6.nabble.com/personalized-schema-plugin-error-td4667319.html
(sorry for the mixup).
Thus: I used schemaPlugin to create the iso19139.mcp-1.4.zip and
iso19139.anzlic.zip and upload it via the administration page to
GeoNetwork. After that, the TransformerConfigurationException appears.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/775#comment:2&gt;
Comment(by simonp):
Actually this is a different bug to Heikki's original but it is fixed in
svn rev 8955 - the bug you have found is restricted to cases where the
schema is uploaded as a zip file - it was triggered during changes for
geonetwork data dir.
(Also note that iso19139.mcp-1.4 depends on iso19139.mcp - you need to
upload both schemas for these to work).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/775#comment:3&gt;
Comment(by sha):
Confirm. The problem I had is indeed fixed with the new revision. I had
revision 8948 or so, one or two days before the 8955.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/775#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: plugin profiles schema
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Re-jig the schemamanager design to remove the distinction between plugin
and built in schemas - all schemas can be plugged in now and they all live
in the same place - the data directory(specifically
data/config/schema_plugins).
See svn rev 8986
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/775#comment:5&gt;
