#796: New user gave Oracle error
Reporter: osjonathan | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version: v2.6.4
Keywords: |
I tried adding a new user and got this error:
SQLException : ORA-00001: unique constraint (GEONETWORK.SYS_C0011916)
violated
Using an Oracle database. The user appears to have been added, though some
googling suggestions that maybe the user already existed, but I don't
remember adding them before so.... :-S
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/796>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by osjonathan):
If I try and delete the user I get this error:
SQLException : ORA-02292: integrity constraint (GEONETWORK.SYS_C0011968)
violated - child record found
Editing the user and changing the user password work fine.
After further investigation, the user did already exist. The bug therefore
is that geonetwork should handle re-registration of the same user much
better than it currently does.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/796#comment:1>
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by simonp):
* status: new => closed
* resolution: => fixed
Comment:
Added a check to make sure that a new user can't be registered with an
existing username - svn revision 8747 - thanks
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/796#comment:2>
