#895: Convert long to clobs and varchar to varchar2 in Oracle setup script and
investigate
Reporter: simonp | Owner: geonetwork-devel@…
Type: task | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Sent: Monday, 7 May 2012 10:43 PM
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Script for Oracle database creation
You would not be the first person to do it... From the following document
it explains how to perform a geonetworks installation and they supply a
modified version of the script which uses CLOB's
http://imos.org.au/fileadmin/user_upload/shared/AODN/EIF023_Implementation_Guide_V1.0.pdf
Personally, I would like to see the geonetwork script modified as dealing
with LONGs are problematic. In our case we would like to query certain
elements within the XML documents using XMLQUERY/XMLTABLE however we
cannot since the data is in a LONG. And it does not looks like there are
any ways to convert LONG to CLOB on the fly without making a custom
function.
Also, as you mention, based on the Oracle documentation, LONG is
depreciated and VARCHAR behaves the same as VARCHAR2 but should not be
used as it is reserved for future use. So I'm not sure why this script
uses LONG or VARCHAR?
We wanted to changed the datatypes in our environment as well however as
we do no want to deviate from the supported documentation with fear that
it may cause issues in the future, we have currently opted to create a
monthly job that copies the data to another table converting the LONG to
CLOB in the process. This means that we are always working with slightly
stale information.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/895>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
