#897: MCP1.4 and ANZLIC schema sample records - no title in search results
Reporter: awalsh | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: search, results |
I build and test GN trunk SVN9041 + ANZMEST schema plugins.
I load the ANZLIC and MCP1.4 sample records and then do
a search. The records appear in the search results but no
title is shown. Looking at the html with Firebug I find
Title element is missing id. no. and text, has only:
<a href="metadata.show?id=&currTab=simple"></a>
but it should be something like this:
<a href="metadata.show?id=4&currTab=simple">Geoscience Australia's Open
Day Photographs 26th August 2007</a>
Further info:
Op. System Windows XP
Java 1.6_07
Jetty
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/897>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Type: defect | Status: closed
Resolution: invalid | Keywords: search, results
Changes (by simonp):
* status: new => closed
* resolution: => invalid
Comment:
Andrew, Please use a later revision of trunk - I suspect you are using
9041 with the latest schema plugins and this will not work due to a change
I made to trunk to save memory in rev 9100. They work for me in 9103.
Thanks - Simon
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/897#comment:1>
Comment(by awalsh):
Hi Simon,
Thanks your suspicion is right. I realise now that I did the 'svn uppate'
a few days after the compiling the trunk and things got out sych. I
compiled
trunk for 9041 but my svn update was much later at 9102.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/897#comment:2>
