[GeoNetwork-devel] [GeoNetwork opensource Developer website] #960: Open for edit a ISO19139-mcp1.4 record resets start/end date to 1970-01-01
Reporter: awalsh | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.8.0 RC0
Component: User interface (web) | Version:
Keywords: |
Using GN trunk v2.8.0 SVN9195 + ANZMEST branch.
I file imported an valid sample ISO19139-MCP record from
our production GN and tested the validation function. In
order to validate the record needs to be opened for edit
Action of opening for edit and then close (no save) actually altered the
start and end date fields i.e this:
<gml:TimePeriod
gml:id="d1e1"><gml:beginPosition>2011-12-05T02:12:00Z</gml:beginPosition><gml:endPosition>2011-12-08T03:46:00Z</gml:endPosition></gml:TimePeriod>
became
<gml:TimePeriod gml:id="d1e1">
<gml:beginPosition>1970-01-01T00:00:00</gml:beginPosition>
<gml:endPosition>1970-01-01T00:00:00</gml:endPosition>
</gml:TimePeriod>
This looks like the same issue as reported in:
http://trac.osgeo.org/geonetwork/ticket/661
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/960&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by ianwallen):
I applied a potential patch.
The approach taken is that if the date/time supplied does not match the
supported format then it places the full text in the date field and leaves
the time field blank. This way nothing is changed.
Also updated code so that it does not fire trigger when loosing focus
which was causing the data to be changed.
The DateTime.js file that was modified seems to be related to a supplied
package. So not sure if we really want to modify this file or it would be
better to use another approach.
Looking for someone to review the patch to see if it makes sense...
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/960#comment:1&gt;
Keywords: |
Comment(by awalsh):
Ian,
Thanks I have applied and tested the patch. I works OK from
respect of not altering a 'Z' date/time however I have not tested
other use cases such as entering date/time and then changing
it.
I notice there a 3 DateTime.js in different places perhaps
some are used by the widgets? interface. Anyway I only
patched the one in web/geonetwork/scripts/map/Ext.ux/form/DateTime.js
From a code point of view I can't review the quality, over to
the developers.....
Andrew
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/960#comment:2&gt;
Keywords: |
I was having issues where dates containing only the year were getting
modified by the interface. I have testing adding different type of data
and it seems to work. Any data containing timezone information (or not
following the date format) will not be able to use the date selector to
update the content. It is not perfect however at least it is not changing
existing data.
I had forgotten about the other 2 DateTime.js files. (thanks for pointing
it out) I'm not sure where they are used.
I'm not 100% sure where the DateTime.js comes from - I found an updated
version from the following site.
http://www.sencha.com/forum/showthread.php?22661-new-version-DateTime-
Field
I also applied the updates to DateTime.js - it looks like they have fixed
some bugs with IE.
So if this is not an official package from extjs (as it seems to have come
from a newsgroup posting) then it should be OK to apply changes to it.
I also found a bug - When using the simple date fields, it was not
accepting simple years as a date. i.e. submitting 2000 was changing the
value to null.
I have made some more corrections and I have submitted a pull request(#26)
to have the changes implemented. (This includes the other 2 DateTime.js
files)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/960#comment:3&gt;
Keywords: Date Time handling |
Changes (by awalsh):
  * keywords: => Date Time handling
Comment:
Ian,
Thanks, good work! looks like you have covered most of the bases.
Jesse,
Thanks for the commit to 2.8.x branch. Once this is all
proven/OK will the change make it into the master branch.
Andrew
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/960#comment:4&gt;
