[GeoNetwork-devel] GeoNetwork opensource v2.6.0 Release Candidate 1 available
!!Note that THIS IS AN UNSTABLE VERSION for testing and that it should not be used in an operational environment!!
Dear all,You can now download and test the latest release candidate (v2.6.0RC1) of GeoNetwork opensource version 2.6.0 from SourceForge.net:
http://sourceforge.net/projects/geonetwork/files/GeoNetwork%20unstable%20development%20versions/v2.6.0RC1/
You will find there:
  • A geonetwork.war file that can be used to deploy in a servlet container (Tomcat, Jetty). This is a special purpose web application recommended for experienced users only.
  • A standard GeoNetwork installer that contains GeoNetwork, GeoServer, Sample data and the servlet container Jetty. This is the recommended file if you want to get a quick start.
The Stable release is planned for end of August. Issues with the Release Candidate can be reported using the Trac system. Issue a ticket with a clear description of the problem at http://trac.osgeo.org/geonetwork/
Thanks to all developers and contributors to make this release possible!
Happy testing! Greetings,
Jeroen
Jeroen Ticheler
GeoCat bv
Irisstraat 52
7531 CW Enschede
Tel: +31 (0)6 81286572
http://geocat.net
Please consider the environment before printing this email.
