Hello,
I have a GeoNetwork 2.8RC0 test installation and I am using the TabSearch
Interface. I would like to configure this to have the GeoNetwork service
installed on a separate server form the GeoServer installation. Is this
possible? If so I do I achieve this?
Byron
View this message in context: http://osgeo-org.1560.n6.nabble.com/GeoServer-on-separate-server-tp4993258.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Okay, I found what I needed to do to make the application use a different
GeoServer host and service. It seems I needed to alter the the following two
files to include the full URL to the geoserver service:
- .. apps/tabsearch/js/Settings.js
- .. apps/tabsearch/js/map/Settings.js
But this by itself was not enough. I needed then to rebuild the project so
that these changes were minified into
- .. apps/tabsearch/js/App-mini.js
Once this was done, and the application redeployed, the changes became
available.
This approach troubles me a bit. What I would like to do is be able to
deploy a GeoNetwork application for an organisation and leave them to be
able to alter these parameters in both Settings.js and map/Settings.js
without requiring them to rebuild the entire GeoNetwork application.
This would require that these two file no longer be minified into
App-mini.js but would instead be downloaded onto the client (in a single
separate Settings-mini.js perhaps) when launching GeoNetwork in their web
browser. I realize that there would be some performance cost involved, but
in my mind the flexibility provided to a system administrator would make
this worth it.
Perhaps I should submit this as an enhancement request? Or is there a better
way to acomplish the same end? One that could provide settings that apply
across all the viewers including the classic GeoNetwork interface and the
gui widgets one.
Byron
View this message in context: http://osgeo-org.1560.n6.nabble.com/GeoServer-on-separate-server-tp4993258p4993274.html
Hello Byron,
2012/8/6 ByronCinNZ <cochranes4@anonymised.com>:
available.
this worth it.
gui widgets one.
I agree with you that modification in minified JS is not easy. For the
map, I was thinking moving the map configuration to a WMC file so we
could a provide a WMC for embedded Geoserver layers, OSM, ...
Do you think we could easily initialized maps from a WMC ? Then we
could add a setting in the DB to choose the map to use.
Cheers.
Francois
Byron
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
loading GN background map settings from WMC sounds nice.
Sample code:
view-source:http://dev.openlayers.org/releases/OpenLayers-2.12/examples/wmc.html
cheers
Jørn-Vegard Røsnes
----- Original Message -----
From: "Francois Prunayre" <fx.prunayre@anonymised.com>
To: "ByronCinNZ" <cochranes4@anonymised.com>
Cc: geonetwork-devel@lists.sourceforge.net
Sent: Monday, 6 August, 2012 8:16:56 AM
Subject: Re: [GeoNetwork-devel] GeoServer on separate server
Hello Byron,
> different
> following two
> project so
> became
> available.
> to
> to be
> map/Settings.js
> application.
> single
> their web
> involved, but
> make
> this worth it.
> a better
> apply
> and the
> gui widgets one.
the
Cheers.
Francois
> Cheers,
> Byron
> Nabble.com.
> Discussions
> malware
Discussions
malware
CONFIDENTIALITY
This e-mail and any attachment contain KONGSBERG information which may be
proprietary, confidential or subject to export regulations, and is only meant
for the intended recipient(s). Any disclosure, copying, distribution or use is
prohibited, if not otherwise explicitly agreed with KONGSBERG. If received in
error, please delete it immediately from your system and notify the sender
properly.
So I managed to get most everything using a remote Geoserver instance. But
what about the Geopublisher option? Is it possible to use the Geopublisher
if the Geoserver install is on a separate host?
View this message in context: http://osgeo-org.1560.n6.nabble.com/GeoServer-on-separate-server-tp4993258p4993764.html
2012/8/8 ByronCinNZ <cochranes4@anonymised.com>:
Yes, add it on the WEB-INF/geoserver-nodes.xml where you can define
one or more GeoServer nodes (having the REST config extension
installed which is by default in latest GeoServer version).
Cheers.
Francois
