After doing a recursive clone of geonetwork I issues "git submodule status" I
get the following.
8231657532b120b87536a268ff538c3cfced2f13 docs (8231657)
c5cbb7f7d8fb2eae23a1d9cb46775e7ebdcce29e gast (c5cbb7f)
761be66180fd7c2d8ec0952f56b0082422d5e04c geoserver (heads/master)
22b6e3087520a2e230f938b4292c9f7cbfa6441f installer (remotes/origin/2.8.x)
2d6c678f2ffae001e9381104d73c7abc6424ac0f maven_repo (heads/master)
eac8be9041ca462e1adfe29fd727f2132e172df4 release (eac8be9)
8fbbf8ace4e02d4173f36b71064b5e92be91d9c9 web-itest/webspecs
(remotes/origin/geo
cat_1.0-36-g8fbbf8a)
Is there a reason the installer points to a 2.8.x branch?
View this message in context: http://osgeo-org.1560.n6.nabble.com/git-installer-submodule-on-master-is-incorrect-tp5027582.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
It is probably a mistaken merge from 2.8 or a cherry pick that caused this. I will update it to point to master
On Tue, Jan 15, 2013 at 2:18 PM, ianwallen <ianwallen@anonymised.com> wrote:
After doing a recursive clone of geonetwork I issues “git submodule status” I
get the following.
(remotes/origin/geo
Master SQL Server Development, Administration, T-SQL, SSAS, SSIS, SSRS
and more. Get SQL Server skills now (including 2012) with LearnDevNow -
200+ hours of step-by-step video tutorials by Microsoft MVPs and experts.
SALE $99.99 this month only - learn more at:
http://p.sf.net/sfu/learnmore_122512
GeoNetwork-devel mailing list
Jesse,
- I did not know that a cherry pick could cause this??? Good to know.
Thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/git-installer-submodule-on-master-is-incorrect-tp5027582p5027586.html
Jesse,
While you are at it - would you mind updating the release submodule for the
2.8.x branch as well. It is one commit behind....
Thank you.
+1e1d4a0f15e0ecff995115719637920d1489d8bf docs (remotes/origin/2.8.x)
b0a866008a1bcbcbf5a1c4d3e67426c84848314e gast (heads/2.8.x)
4471bd724a5d8dea527607f957215edac7f5af2a geoserver (heads/2.8.x)
22b6e3087520a2e230f938b4292c9f7cbfa6441f installer (heads/2.8.x)
3a7ddf615f8410fa97933fcc5e2ec6729d4a0e76 maven_repo (heads/2.8.x)
7da1e3d9e291ec788ce4bf9c6ba0b3e994559952 release (*7da1e3d*)
2465f663daa2fb4c40930e548301979aefea715b web-itest/webspecs
(remotes/origin/geonetwork/2.8.x)
View this message in context: http://osgeo-org.1560.n6.nabble.com/git-installer-submodule-on-master-is-incorrect-tp5027582p5027601.html
