Is there a plan to support gmx:Anchor elements in iso19139?
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Adanac Drive
Southampton SO16 0AS
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
Hi Justin,
I do not believe that there is intention to add HTML or XHTML tags into the XML Schema implementation of ISO 19115 and its related standards. ISO 19139 is meant to be the XML Schema implementation of ISO 19115 and is not considering presentation components.
I believe that the intention is for presentation to be managed by an XSLT from the valid ISO 19139 XML into XHTML or HTML or any other format that one requires.
I hope that this helps.
John
From: Justin Rowles (C) [mailto:Justin.Rowles@anonymised.com]
Sent: Wednesday, 13 July 2011 12:18 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] gmx:Anchor
Justin.
Ordnance Survey
Adanac Drive
Tel: 08456 050505
