[GeoNetwork-devel] GN 3.0.x not building
as reported in another thread, the official nighly builds (http://nightlybuild.geonetwork-opensource.org/trunk/) are not building since 25/12.
Our jenkins reports the first build failure on 15/12/2015.
You can check the build logs at
    http://build.geo-solutions.it/jenkins/job/GeoNetwork-3.0.x-Nightly/
The errors in the latest build are the same as the ones on 15/12.
This is the log reporting the commits which initially caused the failure
(I'm pasting it here because the related build has been removed from the
Jenkins history):
Changes:
[breuil] Check that the md extent is valid before calling fit() (#1308)
[breuil] Use gnMap functions to add the layer to the map and properly zoom to it
[breuil] Allow GeonetworkDataDirectory sub-paths to be set via bean properties
[breuil] add missing setter for uploadDir
[fx.prunayre] Fix 2.10.4 > 3.x migration due to wrong package name. Fix 3.0.2 > 3.0.3 migration is made first by hibernate, then by the SQL.
[fx.prunayre] Improve csw:Record support.
[fx.prunayre] Harvester / CSW / If outputSchema defined, set the appropriate typename. If not set, fallback to previous mechanism. Some CSW server does not well support
multiple comma separated typenames.
[fx.prunayre] Update from transifex.
[fx.prunayre] JSLint.
[fx.prunayre] Harvester / CSW / Infinite loop #1355.
[fx.prunayre] Fix CSW tests.
[fx.prunayre] Harvester / CSW / Fail to set criteria when duplicates in SupportedISOQueryables #1356.
[fx.prunayre] Update version to 3.0.3-0
[fx.prunayre] Update version to 3.0.4-SNAPSHOT
[fx.prunayre] Add migration script for 3.0.4.
Is GeoNetwork building properly in your environment?
   Emanuele
Visit http://goo.gl/NWWaa2 for more information.
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
Hi Emanuele,
2016-01-08 12:57 GMT+01:00 Emanuele Tajariol <etj@anonymised.com>:
(I’m pasting it here because the related build has been removed from the
Jenkins history):
Changes:
Looks good on travis.
https://travis-ci.org/geonetwork/core-geonetwork/builds/101039009
but travis is skipping tests so not a good indicator! Do you know how to turn them on ?
The issue looks to come from
java.lang.AssertionError: /work/nodes_node1/config/schema_plugins/iso19139/index-fields/default.xsl expected:<56800> but was:<56669>
at org.junit.Assert.fail(Assert.java:93)
at org.junit.Assert.failNotEquals(Assert.java:647)
at org.junit.Assert.assertEquals(Assert.java:128)
at org.junit.Assert.assertEquals(Assert.java:472)
at org.fao.geonet.GeonetTestFixture$CompareDataDirectory.visitFile(GeonetTestFixture.java:316)
Without the check https://github.com/geonetwork/core-geonetwork/blob/develop/core/src/test/java/org/fao/geonet/GeonetTestFixture.java#L314, test are ok. I don’t see why the default.xsl does not have the same size. Any idea ?
Francois
Emanuele
Technical Lead
GeoNetwork-devel mailing list
Hi
I just build 3.0.x branch locally (mvn clean install), using the latest revision:
commit 51a4a6fcc371d8c7ffa784b4fc5ccdf4af96344f
Merge: 3b16691 849951f
Author: François Prunayre <fx.prunayre@anonymised.com>
Date: Fri Jan 8 12:30:59 2016 +0100
And builds fine for me, using Java 7 and Maven 3.1.1
Jose García
On Fri, Jan 8, 2016 at 2:14 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi Emanuele,
Jenkins history):
Changes:
Francois
Emanuele
Technical Lead
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
turn them on ?
They actually are launched, but travis on java projects (when maven is
detected) begins with a mvn clean install -DskipTests (so that the .m2
is populated with the necessary dependencies as well as the actual
application), see line #133 and #5067 of the travis-ci output from
your previous link.
-- Pierre
