[GeoNetwork-devel] Groovy full view formatter
Hi
Maybe someone has an idea of what can be causing this issue that is driving me really crazy. When trying to access the full metadata view in the detail page or print to pdf I get this exception and nothing is displayed to the user:
org.fao.geonet.services.metadata.format.groovy.template.TemplateException: There is no object in the model map with the id ‘g’ in the model map. The model selection expression is: g.src’.
The current options are:
[graphics, label]
at org.fao.geonet.services.metadata.format.groovy.template.TRenderContext.getModelValue(TRenderContext.java:123)
at org.fao.geonet.services.metadata.format.groovy.template.TRenderContext.getModelValue(TRenderContext.java:97)
at org.fao.geonet.services.metadata.format.groovy.template.TextContentReplacement.text(TextContentReplacement.java:21)
at org.fao.geonet.services.metadata.format.groovy.template.TextBlock.render(TextBlock.java:23)
at org.fao.geonet.services.metadata.format.groovy.template.TNodeTextContent.render(TNodeTextContent.java:21)
at org.fao.geonet.services.metadata.format.groovy.template.FileResult.toString(FileResult.java:29)
at java.lang.String.valueOf(String.java:2847)
at java.lang.StringBuilder.append(StringBuilder.java:128)
at org.fao.geonet.services.metadata.format.groovy.Handler.processResult(Handler.java:75)
at org.fao.geonet.services.metadata.format.groovy.Handler.handle(Handler.java:55)
at org.fao.geonet.services.metadata.format.groovy.TransformEngine.processElement(TransformEngine.java:76)
at org.fao.geonet.services.metadata.format.groovy.TransformEngine.processChildren(TransformEngine.java:110)
at org.fao.geonet.services.metadata.format.groovy.TransformEngine.processElementsInMode(TransformEngine.java:33)
at org.fao.geonet.services.metadata.format.groovy.Handlers.processElementsInMode(Handlers.java:586)
at org.fao.geonet.services.metadata.format.groovy.Handlers.processElements(Handlers.java:557)
at org.fao.geonet.services.metadata.format.groovy.Handlers$processElements$7.call(Unknown Source)
at common.Handlers$_entryEl_closure3.doCall(Handlers.groovy:50)
at sun.reflect.GeneratedMethodAccessor498.invoke(Unknown Source)
Exception is thrown in https://github.com/geonetwork/core-geonetwork/blob/3.0.x/services/src/main/java/org/fao/geonet/services/metadata/format/groovy/template/TRenderContext.java#L112-L114
I got similar errors with other metadata with different values of model properties, but for now can’t figure out whats wrong and unfortunately seem there’s no much documentation about this formatter feature or at least I haven’t find it.
If someone has an idea what can be causing this or any point to documentation that can help would be really appreciated.
Jose García
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Seems it happens there https://github.com/geonetwork/core-geonetwork/blob/develop/schemas/iso19139/src/main/plugin/iso19139/formatter/html/graphic-overview.html#L29
The model you send to this template might miss some properties.
Check where it is done, and try to debug it:
https://github.com/geonetwork/core-geonetwork/blob/60dfc3f87019b3760700d89c45ba009d2c5e9bb9/schemas/iso19139/src/main/plugin/iso19139/formatter/groovy/iso19139/Handlers.groovy#L330
So one element of your graphics is either null, or doesnt contain a src property.
On Tue, Apr 5, 2016 at 4:03 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
[graphics, label]
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
GeoNetwork-devel mailing list
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Florent Gravin
0479444492
Hi Florent
Thanks for this. I’ll check as it happens in other metadata for different model properties.
Related to the debug of groovy code, is it possible to add some debug messages in groovy files to get logged in geonetwork.log file? I’m not very use to groovy.
Jose García
On Tue, Apr 5, 2016 at 4:13 PM, Florent Gravin <florent.gravin@anonymised.com.189…> wrote:
Hi
[graphics, label]
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
camptocamp
Florent Gravin
0479444492
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
I’m not used either.
You should be able to configure your Intellij to debug the groovy code, i don’t know how, but Jesse did debug the groovy.
Otherwise, just print thing in the metadata to debug (return something from your handler).
I dont really know, i haven’t really worked on this part.
On Tue, Apr 5, 2016 at 4:27 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Florent
Jose García
On Tue, Apr 5, 2016 at 4:13 PM, Florent Gravin <florent.gravin@anonymised.com9…> wrote:
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi
[graphics, label]
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
camptocamp
Florent Gravin
0479444492
camptocamp
Florent Gravin
0479444492
Hi Florent
Thanks again for your help.
I can’t debug from IntelliJ as the problem occurs in a server where I have very limited access. Unfortunately, locally with a similar configuration works fine. So most probably is related to some configuration difference, but nothing obvious and unfortunately the error thrown is not very clear and makes things really hard.
Jose García
On Tue, Apr 5, 2016 at 4:30 PM, Florent Gravin <florent.gravin@anonymised.com> wrote:
Hi Florent
Jose García
camptocamp
Florent Gravin
0479444492
On Tue, Apr 5, 2016 at 4:13 PM, Florent Gravin <florent.gravin@anonymised.com> wrote:
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi
[graphics, label]
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
camptocamp
Florent Gravin
0479444492
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi
Finally cleaning the formatter folder before a deployment, looks fixing partially. The first record I try shows up the full view, but for next records the following error is displayed in the console:
Apache Tomcat/7.0.42 - Error report
HTTP Status 500 - Request processing failed; nested exception is java.lang.RuntimeException: org.h2.jdbc.JdbcSQLException: Database may be already in use: "Locked by another process". Possible solutions: close all other connection(s); use the server mode [90020-174]
type Exception report
message Request processing failed; nested exception is java.lang.RuntimeException: org.h2.jdbc.JdbcSQLException: Database may be already in use: "Locked by another process". Possible solutions: close all other connection(s); use the server mode [90020-174]
description The server encountered an internal error that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.RuntimeException: org.h2.jdbc.JdbcSQLException: Database may be already in use: "Locked by another process". Possible solutions: close all other connection(s); use the server mode [90020-174]
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:965)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:844)
javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
root cause
jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:98)
jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:24)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:856)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:953)
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:829)
javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
Seem the cache is using a h2 database to store the cached formatters, that unfortunately in my customer setup causes some lock issues, what is really unfortunate. Not clear why not used the default database setup in GeoNetwork for the cache, instead of adding a new level of complexity with a new db in the system for the cache, but possibly I’m missing something here.
At least disabling the cache seem somehow working, with the downside of taking ages (and this unfortunately not a joke) to show the full view for the records. Maybe would be better to get back to the old xslt formatter for full view until this groovy/cache stuffs works fine.
Jose García
On Tue, Apr 5, 2016 at 4:35 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Florent
Jose García
On Tue, Apr 5, 2016 at 4:30 PM, Florent Gravin <florent.gravin@anonymised.com89…> wrote:
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Florent
Jose García
camptocamp
Florent Gravin
0479444492
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi
[graphics, label]
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
camptocamp
Florent Gravin
0479444492
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi
Solved the issue with the lock using ;AUTO_SERVER=TRUE when creating the h2 connection in FilesystemStore. Also now the rendering looks much faster, not sure if related to this or previously the server had some performance issue.
I’ll test a bit more that doesn’t cause issues and will commit the change.
Jose García
On Wed, Apr 6, 2016 at 11:19 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
exception
root cause
Jose García
Hi Florent
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Florent
Jose García
camptocamp
Florent Gravin
0479444492
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
On Tue, Apr 5, 2016 at 4:03 PM, Jose Garcia <jose.garcia@anonymised.com…> wrote:
Hi
[graphics, label]
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
camptocamp
Florent Gravin
0479444492
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Note that you can clear formatter cache from admin console.
On Wed, Apr 6, 2016 at 12:25 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
Jose García
Hi
exception
root cause
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Florent
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
On Tue, Apr 5, 2016 at 4:30 PM, Florent Gravin <florent.gravin@anonymised.com9…> wrote:
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Florent
Jose García
camptocamp
Florent Gravin
0479444492
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi
[graphics, label]
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
camptocamp
Florent Gravin
0479444492
camptocamp
Florent Gravin
0479444492
Hi Florent
Sure, we tried but that didn’t solve the issue with the lock of the H2 database. For now, adding the ;AUTO_SERVER=TRUE to the db connection string seem doing the trick in this setup.
Thanks for the feedback provided.
Jose García
On Wed, Apr 6, 2016 at 12:30 PM, Florent Gravin <florent.gravin@anonymised.com> wrote:
Hi
Jose García
camptocamp
Florent Gravin
0479444492
Hi
exception
root cause
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Florent
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Florent
Jose García
camptocamp
Florent Gravin
0479444492
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi
[graphics, label]
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
camptocamp
Florent Gravin
0479444492
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
On 04/05/16 16:03, Jose Garcia wrote:
Hi
    There is no object in the model map with the id 'g' in the model
    map. The model selection expression is: g.src'.
As forthis particular error, maybe see
https://github.com/geonetwork/core-geonetwork/issues/1350 ? This reminds
me of the cryptic error i had which really drove me crazy..
Landry
Hi
Thanks Landry, i’ll check in my environment. For now i have it working in a dev environment, but not in stage that is supposed to be the same. So can’t move to production.
I’m pretty sure i got it working in both environments at certain moment, but was facing other issues with the h2 formatter cache and moved the cache to the gn database and actually the stage environment is not working.
Unfortunatelly issues in the formatter throw really obscure errors that makes loosing lots of time and patience.
Jose García
Hi
me of the cryptic error i had which really drove me crazy…
Landry
GeoNetwork-devel@anonymised.comt
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
