[GeoNetwork-devel] Harvest matches more than one schema
Hello,
I tried to make a harvest, but I find myself unretrievable. When checking
the log all records were not collected for the following reason:
Metadata record with MD_Metadata (Namespace: [namespace: prefix "gmd" is
mapped to URI "http://www.isotc211.org/2005/gmd"\] matches more than one
schema - namely: [iso19139, iso19139.bmg] - during schema autodetection mode
1
SchemaMatchConflictException: Metadata record with MD_Metadata (Namespace)
[Namespace: prefix "gmd" is mapped to URI
"http://www.isotc211.org/2005/gmd"\] matches more than one schema - namely:
[iso19139, iso19139.bmg] - during schema autodetection mode 1
The schema iso19139.bmg was a customization made from the
iso19139. I would like the metadata imported from that match with
iso19139.bmg
Any idea?
Note: I am using version 3.4.4 and performing a harvest of a node 2.10.0
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-developer-f3874395.html
Hi Tarcísio,
To me, it sounds like your schema-ident.xml for iso19139.bmg is too similar (possibly even identical?) to the schema-ident.xml for (built-in) iso19139.
(Schema-ident.xml for iso19139 in Geonetwork 3.4 can be found here https://github.com/geonetwork/core-geonetwork/blob/3.4.x/schemas/iso19139/src/main/plugin/iso19139/schema-ident.xml )
If you want to import iso19139 records as iso19139.bmg instead of iso19139, you will probably need to make the core iso19139 schema-ident.xml not work for the same records… e.g., make it so iso19139/schema-ident.xml will never accept a record, for example by adding a custom namespace to the schema declaration and specifying that namespace as an element within the section.
If you have specially crafted metadata elements, extensions, or namespaces, you should make iso19139.bmg/schema-ident.xml more specific instead. (e.g., if your records use Marine Community Profile/MCP elements, make sure you’re checking for the mcp namespace declaration)
Hopefully that helps!
Kim
From: Tarcísio Silva de Araújo tarcisio.saraujo@anonymised.com
Sent: 03 May 2019 15:40
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Harvest matches more than one schema
Hello,
Metadata record with MD_Metadata (Namespace: [namespace: prefix “gmd” is
mapped to URI “http://www.isotc211.org/2005/gmd”] matches more than one
1
[Namespace: prefix “gmd” is mapped to URI
“http://www.isotc211.org/2005/gmd”] matches more than one schema - namely:
iso19139.bmg
Any idea?
GeoNetwork-devel mailing list
Hi All,
I noticed that GeoNetwork uses wro4j to compile LESS files to css. But in my case, the imports are not being processed. The browser did find a css file (eg, gn_search_default.css), however the content of that css file is exactly the same as the less file, it has the @import “xxx.less” and the less syntax, so the browser doesn’t understand the style and not display the content correctly. I found one issue from the github repository (https://github.com/geonetwork/core-geonetwork/issues/2535). But seems like my issue is kinda different than this one, the import location is correct.
Also when I use mvn install, I successfully created the .war file with no error messages. It’s just that the less file not been correctly compiled.
Any ideas would be appreciated.
Thanks
(attachments)
Zhuoyue Zhou
Hello Kim,
I did the following:
<autodetect xmlns: bmg = &quot;http://geoportal.ide.ba.gov.br/bmg&quot;
xmlns: gmd = &quot;http://www.isotc211.org/2005/gmd&quot;
xmlns: gco = &quot;http://www.isotc211.org/2005/gco&quot;&gt;
<elements>
<gmd: metadataStandardName>
<gco: CharacterString> EMG-Bahia, ISO 19115: 2003 / Cor.1: 2006
Profile </ gco: CharacterString>
</ gmd: metadataStandardName>
</ elements>
</ autodetect>
Thank you for your help.
