[GeoNetwork-devel] Harvested records not appearing in Geonetwork [SEC=UNCLASSIFIED]
I am seeing some strange behaviour in Geonetwork all of a sudden, and hoping to get some guidance as to where the problem might be:
  1. We have established a harvesting operation that is expected to retrieve 3 records from a remote CSW service
  2. Running the harvest operation, the history shows that 3 records have indeed been harvested
  3. The records are not showing up in Geonetwork at all, even when logged in as Administrator.
Does anyone have an idea what might be going on here and where we need to be looking for a resolution? We are using Geonetwork 2.10.4-0.
Thanks in advance for any thoughts,
Jon
Can you check the logs to see if there is some error when finishing
the harvesting?
María.
On Tue, Jun 14, 2016 at 1:28 AM, Jon Millard <J.Millard@anonymised.com> wrote:
Jon
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
GeoNetwork-devel mailing list
