Hi César,
it seems you configured different kinds of harvester in the two machines.
One is set for using a CSW interface, so you see the URLs related to CSW getRecord calls;
see
CSW Harvesting - GeoNetwork Opensource
The other one is configured as a GeoNetwork harvester, so the harvester is calling GN specific services (mef.export);
see
GeoNetwork Harvesting - GeoNetwork Opensource
Both of them should work anyway.
You may want to give a look to your proxy configuration, since it seems that
the paths are not the default ones and this may lead to some misconfigurations.
Emanuele
PS: I guess this mail should have been directed to the geonetwork-users list.
Alle 15:36:38 di Wednesday 30 September 2015, César Díaz García ha scritto:
We are running into some problems while trying to do harvesting against a
Geonetwork 2.10.4 we have installed and set up recently. The issue is that
from a test machine, where another Geonetwork 2.10.4 is installed, we are
able to harvest all the metadata successfully. However, from another
machine running a Geonetwork 2.10 and with the same harvesting
configuration, only 72 metadata are harvested, because the execution fails
abruptly.
Digging into the cause of the problem we have found out that the requests
to get each harvested metadata are different depending on which of the two
machines we are using.
The test that performs OK asks for the metadata with URLs of the form:
· GET
/ogc/csw?request=GetRecordById&service=CSW&version=2.0.2&outputSchema=http
%3A%2F%2Fwww.isotc211.org%2F2005%2Fgmd&elementSetName=full&id=spaSITNAortof
oto_2000_Zilbeti_2008.xml HTTP/1.1
However, the failing one is using URLs similar to the following:
· GET
/ogc/csw/srv/en/mef.export?uuid=spaSITNAortofoto_2000_Zilbeti_2008.xml&for
mat=partial HTTP/1.0
As you can see, the have nothing to do. Any of you have experienced
something similar? Any clue on what can be causing the problem (the
difference on the requests)? Any help would be much appreciated.
Best regards,
César
AVISO SOBRE CONFIDENCIALIDAD: La información incluida en este mensaje es
CONFIDENCIAL y de uso EXCLUSIVO a su FINALIDAD. Su posterior divulgación
será responsabilidad de quien la realice
Visit GeoSolutions for more information.
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
