[GeoNetwork-devel] head
I want to create metadata into geonetwork but I’m unable to create as it is showing following errors please help me out
[ISOFTDS19139:2005-TableA1-Row10] - Content mandatory for dataset or series
  • Statement is mandatory if no source or process step defined for dataset or a serie. If(count(source) + count(processStep) =0) and (DQ_DataQuality.scope.level = ‘dataset’ or ‘series’) then statement is mandatory.
[ISOFTDS19139:2005-TableA1-Row11 Row12] - Lineage
  • ‘source’ role is mandatory if LI_Lineage.statement and ‘processStep’ role are not documented. Suggestions: Define lineage statement or process step role.
  • ‘processStep’ role is mandatory if LI_Lineage.statement and ‘source’ role are not documented. Suggestions: Define lineage statement or source role.
[ISOFTDS19139:2005-TableA1-Row18] - Distribution format required
  • One distributor format is needed. count (distributionFormat + distributor/MD_Distributor/distributorFormat) > 0.
