[GeoNetwork-devel] header intact
I want to insert metadata into geonetwork but I’m unable to insert as it is showing following errors please help me out
[ISOFTDS19139:2005-TableA1-Row10] - Content mandatory for dataset or series
  • Statement is mandatory if no source or process step defined for dataset or a serie. If(count(source) + count(processStep) =0) and (DQ_DataQuality.scope.level = ‘dataset’ or ‘series’) then statement is mandatory.
[ISOFTDS19139:2005-TableA1-Row11 Row12] - Lineage
  • ‘source’ role is mandatory if LI_Lineage.statement and ‘processStep’ role are not documented. Suggestions: Define lineage statement or process step role.
  • ‘processStep’ role is mandatory if LI_Lineage.statement and ‘source’ role are not documented. Suggestions: Define lineage statement or source role.
[ISOFTDS19139:2005-TableA1-Row18] - Distribution format required
  • One distributor format is needed. count (distributionFormat + distributor/MD_Distributor/distributorFormat) > 0.
THANK U!!!
Hi
Seem you have selected the Validate option in the form? Please, uncheck it and should work the import.
Jose García
On Wed, Mar 13, 2013 at 12:01 PM, prachi sain <sainprachi19@anonymised.com> wrote:
THANK U!!!
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
