[GeoNetwork-devel] Help: Records Number drops
That is odd… I assume that no indexing is taking place at the moment? Did you check the logs for out of memory errors?
Jesse
Sent: ‎March‎ ‎14‎, ‎2013 ‎3‎:‎53‎ ‎PM
To: Jesse Eichar <jesse.eichar@anonymised.com>
CC: Devel geonetwork-devel@lists.sourceforge.net
Subject: Re: RE: [GeoNetwork-devel] Help: Records Number drops
Hi Jesse,
It now shows 56794. The file is as below:
http://ec2-54-234-123-20.compute-1.amazonaws.com/geonetwork/srv/eng/q?fast=index&from=1&to=10
It seems it changes over time.
Kai
Joint Center for Intelligent Spatial Computing
703-395-2337
----- Original Message -----
Date: Thursday, March 14, 2013 10:29 am
Subject: RE: [GeoNetwork-devel] Help: Records Number drops
What version of Geonetwork are you using?
Can you run:
and make sure that result agrees with the 25,000 result?
Jesse
Sent: ‎March‎ ‎14‎, ‎2013 ‎3‎:‎22‎ ‎PM
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Help: Records Number drops
Dear Developers,
I used the latest GeoNetwork codes to build a portal on Linux.
There are
about 100,000 records last night, but it shows only 25,000 records
thismorning. However, the database shows all records (100,000)
records are
still in database.
Is this a Lucene problem? I tried rebuild lucene but it will drop
again. I
wonder how I can fix it.
Thanks and best regards,
Kai
703-395-2337
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
GeoNetwork-devel mailing list
Hi Jesse,
I checked the log just now. It doesn't have out of memory problem. I found the lucene files in WEB-INF/data/index/index/eng is very small (about35M). The total size for the records in database is about 2G and I used old geonetwork the lucene index file is 442M!
Maybe the lucene index has never been finished?
Kai
703-395-2337
Date: Thursday, March 14, 2013 11:06 am
That is odd... I assume that no indexing is taking place at the
moment?Did you check the logs for out of memory errors?
Jesse
*Sent:* ‎March‎ ‎14‎, ‎2013 ‎3‎:‎53‎ ‎PM
*To:* Jesse Eichar <jesse.eichar@anonymised.com>
*CC:* Devel geonetwork-devel@lists.sourceforge.net
*Subject:* Re: RE: [GeoNetwork-devel] Help: Records Number drops
Hi Jesse,
Kai
703-395-2337
> Can you run:
> Jesse
> *From:* Kai Liu <kliu4@anonymised.com>
> *Sent:* ‎March‎ ‎14‎, ‎2013 ‎3‎:‎22‎ ‎PM
> *To:* Devel geonetwork-devel@lists.sourceforge.net
> *Subject:* [GeoNetwork-devel] Help: Records Number drops
> Dear Developers,
> There are
> records are
> still in database.
> again. I
> Kai
> 703-395-2337
Hi Jesse,
There are some errors when I restart the GeoNetwork. It seems some gml can't be converted into spatial index. However, I don't think it will stop building index. The error is as below:
2013-03-14 11:55:41,990 ERROR [geonetwork.index] - Failed to convert gml to jts object: <gml:Polygon xmlns:gml="http://www.opengis.net/gml&quot; xmlns="http://www.isotc211.org/2005/gmd&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:srv="http://www.isotc211.org/2005/srv&quot; xmlns:fo="http://www.w3.org/1999/XSL/Format&quot; xmlns:gsr="http://www.isotc211.org/2005/gsr&quot; xmlns:advmis="http://www.geodatenzentrum.de/advmis&quot; xmlns:gts="http://www.isotc211.org/2005/gts&quot; xmlns:gmx="http://www.isotc211.org/2005/gmx&quot; xmlns:geonet="http://www.fao.org/geonetwork&quot; gml:id="ID4454830497488301721" srsName="not defined">
  <gml:exterior>
    <gml:LinearRing>
      <gml:pos>15.0 55.0 0.0</gml:pos>
      <gml:pos>6.0 55.0 0.0</gml:pos>
      <gml:pos>6.0 47.0 0.0</gml:pos>
      <gml:pos>15.0 47.0 0.0</gml:pos>
    </gml:LinearRing>
  </gml:exterior>
</gml:Polygon>
        No authority was defined for code "NOT DEFINED". Did you forget "AUTHORITY:NUMBER"?
org.opengis.referencing.NoSuchAuthorityCodeException: No authority was defined for code "NOT DEFINED". Did you forget "AUTHORITY:NUMBER"?
        at org.geotools.referencing.factory.ManyAuthoritiesFactory.noSuchAuthority(ManyAuthoritiesFactory.java:489)
        at org.geotools.referencing.factory.ManyAuthoritiesFactory.getAuthorityFactory(ManyAuthoritiesFactory.java:467)
        at org.geotools.referencing.factory.ManyAuthoritiesFactory.getCRSAuthorityFactory(ManyAuthoritiesFactory.java:548)
        at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
        at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
        at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
        at org.geotools.referencing.CRS.decode(CRS.java:489)
        at org.geotools.referencing.CRS.decode(CRS.java:417)
        at org.fao.geonet.kernel.search.spatial.SpatialIndexWriter.extractGeometriesFrom(SpatialIndexWriter.java:303)
        at org.fao.geonet.kernel.search.spatial.SpatialIndexWriter.index(SpatialIndexWriter.java:157)
        at org.fao.geonet.kernel.search.SearchManager.indexGeometry(SearchManager.java:715)
        at org.fao.geonet.kernel.search.SearchManager.index(SearchManager.java:698)
        at org.fao.geonet.kernel.DataManager.indexMetadata(DataManager.java:560)
        at org.fao.geonet.kernel.DataManager$IndexMetadataTask.run(DataManager.java:386)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
        at java.lang.Thread.run(Thread.java:662)
Kai
703-395-2337
Date: Thursday, March 14, 2013 11:34 am
Hi Jesse,
Kai
703-395-2337
> Jesse
> Hi Jesse,
> Kai
> 703-395-2337
> From: Jesse Eichar <jesse.eichar@anonymised.com>
> > Can you run:
> > Jesse
> > Dear Developers,
> > There are
> > records are
> > still in database.
> > again. I
> > Kai
> > 703-395-2337
> > _______________________________________________
