[GeoNetwork-devel] How to get the correct uuid when update is done
Hi
I have to update the metadata using the url as follows http://localhost:8080/geonetwork/srv/en/metadata.update ,now what happens is that when insert.metadata was done a new uuid other than what is present in the file gets saved in the database,for instance the uuid present in the file is c8dd9ac5-ff78-4ab5-ada2-69b4132f99fc but after inserting the file the uuid gets changed in the DB and it always ends up with insert scenario is there any method to keep the uuid unchanged
Thanks in advance
Abinav Shankar
Hi
Thanks in advance
Abinav Shankar
