The errors are encountered during use, not during install, so I suppose the problem is not really an installation problem. I was assuming that since people have this working, I must be installing it wrong.
I’ve got Windows 2k, relatively new, plain install. Java is 1.4.2_10. For the purpose of troubleshooting, I’m using the included jetty and mckoi.
Here are the log files that may shed some light on what’s going on. Note that I did not find any logs in geonetwork\web\log. I did enable debug in config.xml.
The setup.log is normal, no errors, all tables are reported as filled (other than Help, which is skipped).
This is for version 2.0.0: I get the “Cannot find the declaration of element ‘Metadata’” error when I try to validate one of the sample xmls, or add new metadata.
These are for version 2.0.1: Sample metadata does not appear at the bottom of main page, login does not work - this is because APP.Users cannot be found. Apparently, the other tables cannot be accessed as well.
debug.log from geonetwork\WEB-INF\db\log
jetty.log from geonetwork\jetty\log
–Paul
**Andrea Carboni <acarboni@anonymised.com>**
Sent by: geonetwork-devel-admin@anonymised.coms.sourceforge.net
2006-01-11 05:26 PM
To
geonetwork-devel@anonymised.comet
cc
Subject
Re: [Geonetwork-devel] Installation problems
Alle 22:35, mercoledì 11 gennaio 2006, pgrzeszc@anonymised.com.65... ha scritto:
> I am unable to successfully install geonetwork. I've tried java 1.4.2_10
> and mysql 5.0 on win2k as well as various permutations with mckoi, jetty,
> tomcat 4.1, tomcat 5, java 1.5 (just in case). I tried on Linux FC3 as
> well. Can someone give me the exact versions that are known to work
> together? What is the recommended setup that is least prone to install
> problems?
> Version 2.0.1 did not install the samples, and the login functionality was
> not working (I was getting the APP.Users error).
> Version 2.0.0 gives the declaration of Metadata element error.
> Thanks
> Paul
Do you get errors during the installation stage or when executing it?
Can you provide more info (i.e. the logs). During the installation there
is a log inside the setup directory while during execution there is a log
inside web/log/. I think you have to edit the web/WEB-INF/config.xml file
and enable debug to have the latter log.
Regarding the platform, I use a debian testing with kernel 2.6.12 and
jdk 1.4.2, with provided jetty and mckoi as servlet engine and dbms.
You can use windows 2000/xp with jdk 1.4.2 from sun. Remember that
jdk 1.5 doesn't work and jvm not from sun have not been tested.
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://ads.osdn.com/?ad_idv37&alloc_id865&op=click
Geonetwork-devel mailing list
Geonetwork-devel@lists.sourceforge.net
(attachments)
debug.log (8 KB)
jetty.log (25.5 KB)
jetty.log (7.67 KB)
