[GeoNetwork-devel] Is there a max number of harvested records from a geonetwork node?
Hi List,
I’m trying to fix an urgent problem with my Geonetwork installation (two servers, both running 2.10), and I was wondering if there’s a limit to the number of records that can be harvested from one geonetwork installation to another? I am consistently seeing 1000 records being harvested when I know there should be more than that. Both servers have the maximum number of selected records set to 2000 in the system configuration.
Thanks
Jo
Jo Cook
t:+44 7930 524 155/twitter:@archaeogeek
Hi Jo
Which harvester type are you using? In any case afaik, should not be any limitation on the number.
I would enable the verbose logging for the harvesters in the log4j.cfg and check the log after executing the harvester to verify if any issue.
Jose García
On Fri, Jun 10, 2016 at 5:07 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi List,
Thanks
Jo
Jo Cook
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18 7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
iShare - enterprise geographic intelligence platform
GeoServer, PostGIS and QGIS training
Helpdesk and customer portal
Company registration no. 5410695. Registered in England and Wales. Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no. 864201149.
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
GeoNetwork-devel mailing list
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
