Hi Andrew,
The XSDs can't implement the constraints of ISO 19115 and ISO 19119. That is
why Schematron is used. Your list of Schematron validation errors are all
related to constraints.
There are few mandatory fields but many conditional fields. Of course all
conditional fields will not be available in the default view because they
only become mandatory under certain conditions.
John
-----Original Message-----
From: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] On Behalf Of Andrew
Chamberlain
Sent: Thursday, 11 September 2008 2:51 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] ISO 19119 Validation
Hi Simon,
Thanks for that.
Just to confirm/paraphrase, if the check gets as far as the schematrons, then
can I assume the metadata is at least valid against the XSDs? I ask because
I was previously getting errors which GeoNetwork itself would pick up and
report (like missing mandatory elements). When I 'fixed' these (by
populating them), I started getting the schematron reports, I wasn't sure if
I was going forwards or backwards!
Regarding the schematron errors themselves, I enclose them below. Not sure
if these are all oddities/anomalies, but either way, I'm rather surprised
that some metadata which adheres to the XSD schema could be so wrong after
all!
So far I've only filled in the elements in the Default View of the metadata.
Is it possible that the errors are due to some of the (mandatory) fields in
the Advanced View being left empty? Please forgive me it should have been
obvious, but I would have thought that a Default View would include all the
mandatory fields?
Andy
Schematron validation for ISO 19115(19139)
CharacterString must have content or it's parent must have a valid nilReason
attribute.
CRS attributes constraints
ISOFTDS19139:2005-TableA1-Row24 - name required
ISOFTDS19139:2005-TableA1-Row07 - otherConstraints required if
otherRestrictions
ISOFTDS19139:2005-TableA1-Row16 - units required for values
ISOFTDS19139:2005-TableA1-Row13 - description required if no sourceExtent
ISOFTDS19139:2005-TableA1-Row14 - sourceExtent required if no description
ISOFTDS19139:2005-TableA1-Row10 - content mandatory for dataset or series
ISOFTDS19139:2005-TableA1-Row11 - source required if no statement or
processStep
ISOFTDS19139:2005-TableA1-Row12 - processStep required if no statement or
source
ISOFTDS19139:2005-TableA1-Row08 - dataset must have report or lineage
ISOFTDS19139:2005-TableA1-Row09 - levelDescription needed unless dataset or
series
* "levelDescription" is mandatory if "level" notEqual 'dataset' or 'series'.
ISOFTDS19139:2005-TableA1-Row17 - units required for density values
ISOFTDS19139:2005-TableA1-Row18 - MD_Format required
ISOFTDS19139:2005-TableA1-Row23 - element required
ISOFTDS19139:2005-TableA1-Row04 - dataset must have extent
ISOFTDS19139:2005-TableA1-Row05 - dataset or series must have topicCategory
ISOFTDS19139:2005-TableA1-Row06 - either aggregateDataSetName or
aggregateDataSetIdentifier must be documented
ISOFTDS19139:2005-TableA1-Row01 - language indication
ISOFTDS19139:2005-TableA1-Row02 - character set indication
ISOFTDS19139:2005-TableA1-Row19 - detail required unless simple term
ISOFTDS19139:2005-TableA1-Row20 - condition
ISOFTDS19139:2005-TableA1-Row21 - domainCode
ISOFTDS19139:2005-TableA1-Row22 - shortName
ISOFTDS19139:2005-TableA1-Row15 - checkPointDescription required if available
Simon.Pigot@anonymised.com wrote:
Hi Andy,
The schematron heading you refer to is just a text string included in the
schematron report xsl - it could be modified to anything we/you want -
schematrons are just rules that end up being applied as an xslt to the
metadata record - they are the second part of the validation process. The
first part of the validation process is against the XSDs - which are the
iso19139 and iso19119 XSDs.
The schematron xslts and XSDs etc are in the appropriate directory in
web/geonetwork/xml/schemas. The schematron rules and instructions for
generating the xslts are in the schematrons directory. The html templates
used to display the report are in schematronCache/schematronscripts. The
schematron report shown tells you that is work from David Carlisle and Rick
Jelliffe but see also
http://xml.ascc.net/resource/schematron/schematron-report.html
I'd be interested to see the validation errors and whether any of them are
oddities/anomalous.
Simon
From: geonetwork-devel-bounces@lists.sourceforge.net on behalf of Andrew
Chamberlain
Sent: Tue 9/9/2008 11:50 PM
Cc:
Subject: [GeoNetwork-devel] ISO 19119 Validation
Hi All,
I'm just testing out the new ISO 19119 support with a trial WMS service.
Everything looks good, but when I perform a check on the metadata, quite
a few errors are reported. I can forward these problems, but first I
was wondering if these errors may be occurring because the wrong schema
is being used to validate the XML? I say this because the Schematron
Report is headed:
"Schematron validation for ISO 19115(19139)"
Should I expect a different heading if the "WMS service in ISO19139/119"
template was used?
Best regards,
Andy
P.S. I realise the code is yet to be included in a stable release, but
I'm happy to be a guinea pig in the meantime.
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-devel mailing list
