Folks,
I've encountered a browser related error in BluenetMEST (v1.1 and change
#1357). The error occurs when using IE7 to perform an ownership transfer.
To reproduce, login as a User Administrator and navigate to
Administration->Transfer ownership.
The error occurs when selecting a user in the source editor drop down list.
Further analysis shows the problem is in ownership/view.js at line 50. This
is where an XSL transform using ownership/client-group-row.xsl is being
performed. Actual code is:
var xslRes = rowTransf.transform(list[i]);
Can any of you AJAX gurus suggest why this is failing? Any documentation
pointers on XSLT support in IE7?
As a general question, what tools are being used to debug javascript in IE7?
Is there an equivalent for Firebug that allows the setting of Javascript
breakpoints, single step & variable inspection?
Stephen
I've just started a new HowTo on debugging at:
http://trac.osgeo.org/geonetwork/wiki/HowToDebug
The answer to your question is "Yes!".
Microsoft Script Editor is the tool I have used to
debug JavaScript in IE. It has some typical
Microsoft clunkiness -- it's a "generic" script
debugger so some of the tools are a bit strange
when used on JavaScript -- but it does let you
do exactly what you are asking for.
Richard Walker
Software Improvements Pty Ltd
Phone: +61 2 6273 2055
Fax: +61 2 6273 2082
Stephan,
One firebug-like tool I have found useful for IE is Debugbar
(http://www.debugbar.com/). It is not open source but it is free for
personal use.
Byron
Stephen.Davies-2 wrote:
Folks,
list.
This
IE7?
Stephen
Sponsored by: SourceForge.net Community Choice Awards: VOTE NOW!
Studies have shown that voting for your favorite open source project,
along with a healthy diet, reduces your potential for chronic lameness
and boredom. Vote Now at http://www.sourceforge.net/community/cca08
GeoNetwork-devel mailing list
View this message in context: http://www.nabble.com/Javascript-error-during-ownership-transfer-(IE7-only)--SEC%3DUNCLASSIFIED--tp18351809p18353749.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
