[GeoNetwork-devel] Log4j Vulnerability
Dear GeoNetwork community,
Can you please advice on which update of GeoNetwork 3.10.x is including the fix for the Log4J security breach ?
I’m (and Edisoft company) are part of the EU project Odyssea that uses currently Geonetwork v3.10.3 and we need to update in order to correct the security issues reported with Log4J.
The project has currently the Geonwetork server down and waiting for a +possible souluction.~
(attachments)
cid:image001.png@anonymised.com
Carlos Figueiredo
Technical Manager / Senior System Analyst
Defence & Security Systems
carlos.figueiredo@anonymised.com
Tel: +351.212945900
Mobile: +351. 937 673 523
Fax: +351.212945999
Rua Calvet Magalhães, 245
2770-153 Paço de Arcos · Portugal
www.edisoft.pt
cid:image002.png@anonymised.com345...
A informação contida neste e-mail e quaisquer documentos anexos são propriedade da EDISOFT e poderão ser confidenciais. Se não for o destinatário pretendido, por favor, comunique-nos de imediato, enviando-nos esta mensagem de volta e destruindo-a em seguida. Fica desde já advertido de que é estritamente proibida qualquer revisão, divulgação, distribuição, cópia ou qualquer outra utilização deste e-mail.
The information contained in this e-mail and any attachments are the property of EDISOFT and may be confidential. If you are not the intended recipient, please notify us immediately, send this message back to us and destroy it. You are hereby notified that any review, dissemination, distribution, copying or otherwise use of this e-mail is strictly prohibited
Hi Carlos
Please check:
Both versions have the log4j2 version 2.15.0. The source code is updated to 2.17.0, but for now there are no official releases including that version.
Jose García
(attachments)
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Thank you José.
Happy New Year.
(attachments)
cid:image001.png@...1345...
Carlos Figueiredo
carlos.figueiredo@…1177…
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
cid:image002.png@...1345...
Sent: 3 de janeiro de 2022 11:36
To: FIGUEIREDO Carlos <carlos.figueiredo@…1177…>
Cc: geonetwork-devel@lists.sourceforge.net; TILSNER Dirk <dirk.tilsner@…1177…>
Subject: Re: [GeoNetwork-devel] Log4j Vulnerability
Hi Carlos
Please check:
Jose García
On Mon, Jan 3, 2022 at 12:17 PM FIGUEIREDO Carlos via GeoNetwork-devel <geonetwork-devel@lists.sourceforge.net> wrote:
Can you please be so kind to inform me of the above ?
Many thanks for you attention to this subject.
BR
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
GeoNetwork-devel mailing list
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi José,
Just another information: it seems that the geonetwork 3.10.10 war package still includes in the JMSAppender.class ,the log4j-1.2.17.jar.
It is expected to release another 3.10.x version with this removed (version 1 of Log4J as it seems redundant ?) and eventually also upgrade with log4j 2.17.x ?
Many thanks for your attention ad help on this subject.
BR,
(attachments)
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Hi Carlos
Please check:
Jose García
BR
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Jose García
https://www.geocat.net/wp-content/uploads/2015/07/GeoCat_small1.png
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi José,
One additional question: if Geonetwork can function without the usage cookies ?
Thank you for your attention and best regards,
(attachments)
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Sent: 5 de janeiro de 2022 11:22
To: ‘Jose Garcia’ <jose.garcia@…437…>
Subject: RE: [GeoNetwork-devel] Log4j Vulnerability
Hi José,
BR,
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Hi Carlos
Please check:
Jose García
BR
Carlos Figueiredo
Tel: +351.212945900
Fax: +351.212945999
www.edisoft.pt
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Carlos
About log4j-1.2.17.jar, afaik version 1.2 is not affected by the bug. GeoNetwork uses that version for logs, the log4j version 2 is included as part of another library used in GeoNetwork, but it’s not really used for the logs.
About the cookies, I don’t think the usage can be removed from GeoNetwork.
Jose García
(attachments)
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
