In GeoNetwork 2.2 we had clear markings for fields that were mandatory or conditionally required in the ISO standard AFAIK, Ik the version 2.4.0 I miss this information and I'm not sure why it was removed. I am personally not in favor of hiding this information. Anyone knows about this issue?
Thanks in advance, ciao,
Jeroen
Hi Jeroen,
It was removed in the BlueNetMEST code that was merged in to the editor. I'll restore it to the trunk code shortly.
Simon
_________________________
From: Jeroen Ticheler [Jeroen.Ticheler@anonymised.com]
Sent: Friday, 29 May 2009 8:39 PM
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Mandatory and optional fields in ISO
about this issue?
Jeroen
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals. Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, &
iPhoneDevCamp as they present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. Best Open Source Mac Front-Ends 2024
GeoNetwork-devel mailing list
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hello Jeroen & Simon
2009/5/29 <Simon.Pigot@anonymised.com>:
Could we retrieve this information from schema or from labels.xml
mandatory flag ?
Ciao. Francois
Simon
Subject: [GeoNetwork-devel] Mandatory and optional fields in ISOHi all,
about this issue?
Jeroen------------------------------------------------------------------------------
Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com
GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork------------------------------------------------------------------------------
Hi Francois,
I think schema is safest for the mandatory test - the labels file is kind of hard to use I think because the same element can get used in different places in the xml tree eg. extent is conditional in MD_DataIdentification if hierarchyLevel is dataset and optional elsewhere.
Simon
________________________________________
From: Francois-Xavier Prunayre [francois-xavier.prunayre@anonymised.com]
Sent: Friday, 29 May 2009 10:49 PM
To: Pigot, Simon (CMAR, Hobart); Jeroen.Ticheler@anonymised.com
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Mandatory and optional fields in ISO
mandatory flag ?
Ciao. Francois
Simon
about this issue?
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net------------------------------------------------------------------------------
Ok Simon,
And why did you remove that from Bluenet ? any metadata editor wishes ?
Cheers. Francois
Hi Francois,
Simon________________________________________
Subject: Re: [GeoNetwork-devel] Mandatory and optional fields in ISOHello Jeroen & Simon
mandatory flag ?Ciao. Francois
Simon
about this issue?
