[GeoNetwork-devel] Maven plugin repository failure
I have tried to rebuild 2.10.x version of geonetwork on a clean
environment and I find some problems with the sonatype repository for
maven plugins. If we remove this and use the default one, it works.
Why are we using this repository? Do you know what happened? Can we
just use the default or something else will be broken?
María.
