I am using the following tutorial http://geonetwork-opensource.org/documentation/tutorial/administration/setupdruid to connect to a GN 2.4.2 Mckoi DB through Druid.
How do I retrieve the DB's user name and password?
The GN 2.4.2 installer does not prompt one to set Mckoi's authentication info.
Ciao, WG
_______________________________
Wolfgang Grunberg
Arizona Geological Survey
wgrunberg@anonymised.com
520-770-3500
The MckoiDB login information is automatically generated in GN 2.4.2 and stored in the following file geonetwork\WEB-INF\db\account.prop
What can I do to update the tutorial?
WG
Wolfgang Grunberg
520-770-3500
Ciao, WG
Ask Jeroen Ticheler to do so, ideally suggesting a better text. Maybe, instead of
“Enter the username and password you selected during the installation of geonetwork for the McKoi database”
let’s put
"Enter the username and password randomly generated by GAST during the installation, which you can find in … <etc.> "
Jeroen ?
On Fri, Nov 13, 2009 at 8:05 PM, Wolfgang Grunberg <wgrunberg@anonymised.com> wrote:
WG
Wolfgang Grunberg
520-770-3500
How do I retrieve the DB’s user name and password?
The GN 2.4.2 installer does not prompt one to set Mckoi’s authentication
info.
Ciao, WG
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what’s new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-devel mailing list
I updated the tutorial as suggested. Thanks for the update!
Ciao,
Jeroen
let’s put
Jeroen ?
WG
Wolfgang Grunberg
520-770-3500
info.
Ciao, WG
Crystal Reports now. http://p.sf.net/sfu/bobj-july_______________________________________________
