Hi, has anyone tried to store uploaded data into a nextcloud server ?
JCloud does not look to support that.
2 approaches maybe:
- use nextcloud external storage to mount the data dir directly in readonly mode (using the default filesystem store)
- or use the webdav API of nextcloud.
Also would it make sense to have a folder structure simply based on UUID instead of a group of 100 records as first level folder, then db id folder and make this configurable ?
Any suggestions?
Thanks.
Francois
2 approaches maybe:
To me it makes sense to define a WebDAV connector instead something specific for Nextcloud.
Using just the UUID can create huge index pages that take a lot of time to load if you have many records. It also will create the same files per directory limits problems in the backend than using local storage.
Vriendelijke groeten / Kind regards,
Juan Luis Rodríguez.
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
