Hi Arturo,
That´s the address I use to connect to a "GeoNetwork 2.1.0 alpha1" catalogue
using gvSig and selecting CSW as the connection protocol.
http://localhost:7070/geonetwork/srv/en/csw
although the 7070 port depends on the GN port you used for the GN
installation.
Walter BARBERA
I+D Project Engineer
GTD SISTEMAS DE INFORMACIÓN
Pg. Garcia Fària, 17 E-08005 Barcelona
Tel.: +34 934 939 300 Fax: +34 934 939 334
www.gtd.es - walter.barbera@anonymised.com
-----Mensaje original-----
De: Arturo Beltran Fonollosa [mailto:fonollos@anonymised.com]
Enviado el: jueves, 22 de marzo de 2007 9:54
Para: Walter Barbera
CC: geonetwork-devel@lists.sourceforge.net
Asunto: RE: [GeoNetwork-devel] Metadata insert
On Wed, 21 Mar 2007, Walter Barbera wrote:
You can access GN via
URL example: http://localhost:7070/geonetwork/srv/en/csw
Yes, but the result is:
Service not found.
Service not found : csw
I have GeoNetwork v2.0.3 . I must install this sevice separately?
Thanks
Walter BARBERA
De: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] En nombre de
Arturo
Beltran Fonollosa
Enviado el: miércoles, 21 de marzo de 2007 12:12
Para: geonetwork-devel@lists.sourceforge.net
Asunto: [GeoNetwork-devel] Metadata insert
I'm programming a gvSIG extension that inserts metadata in a GeoNetwork
Server.
I think that the best option is to do a POST petition to
/geonetwork/srv/es/metadata.insert like the "XML Metadata Insert" option
does.
This POST petition would include:
data -> XML String
group -> id of a user group in geonetwork
schema -> iso19115 or other (Can we include more schemas?)
validate
Do you think this is the best option to insert metadata from an external
application?
Which are exactly the schemas or DTDs that geonetwork uses to validate the
XMLs? Can you send me the schemas?
I suppose that, in order to do the insert, you must log in first, how can
i do this?
I looked for some documentation about how to access to the Geonetwork's
CS-W interface and did some tests, but I couldn't access, how can i do
this?
Thanks
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys-and earn cash
GeoNetwork-devel mailing list
