Hi Michael,
I'm sorry I didn't respond to you previous email. I have been busy.
I believe that your method of using MD_AggregationInformation is one way of
making that connect between metadata records if you feel that the search for
"those who have myself as a parentidentifier" is not suitable.
If you are relating "series", "dataset", "featureType" etc. metadata then you
could use the DS_DataSet element which "has" many metadata records. I think
that GeoNetwork implements this but I am not sure.
This probably doesn't help much but I'm glad to see that someone else is
thinking about how to relate metadata.
Thanks.
John
-----Original Message-----
[mailto:metadata-bounces@anonymised.com] On Behalf Of
Michael Östling
Sent: Tuesday, 3 October 2006 3:52 AM
To: metadata@anonymised.com
Subject: [metadata] Use of ParentIdentifier and Aggregation
InformationHi,
I put a question a week ago on use of hierachical metadata.
The questions was probably to fuzzy to get a simple answer on.I therefore make an other in the same area.
The use of the element ParentIdentifier.
With use of these it makes it possible to make a parent
/child relationship
for hierarchical records.A drawback is though that if you have a parentrecord and
wants to see "where
are my childs" I have to go through all other records to find
those who have myself as a parentidentifier. To solve this I have used
MD_AggregationInformation and added "isPartOf" and
"areComposedOf" to the
associationTypeCodes.In this way I can solve 1:m relations.
The questions is though if this is a good way to add relations for
describing hierarchical relations between metadatarecords.Is there someone who have other ideas on this?
Regards
Michael------------------------------------------------------------------
MetaGIS AB
Michael Östling
Mob: 070-279 19 76
Tel: 023 - 702 20 10
ePost: michael.ostling@anonymised.com
Adress: Britsarvsvägen 28a, 791 36 FALUN,Sweden
Org Nr: 556638-7170------------------------------------------------------------------
Internal Virus Database is out-of-date.
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.12.9/456 - Release
Date: 2006-09-25_______________________________________________
metadata mailing list
http://lists.geocomm.com/mailman/listinfo/metadata_____________________________________
This List is brought to you by:
The GeoCommunity and The GISDataDepot
http://www.geocomm.com/ | http://data.geocomm.com/
