humbly chiming in, mostly to explain why GeoServer has that direction for
bug fixes.
One has already been cited by Ian, to avoid losing them. In a perfect world
one would fix the stuff and then
port the fix to master as well, but life is sometimes a bit more
complicated, e.g, you fix the bug on stable,
then get into a meeting, or some emergency investigation, or a vacation,
whatever, and forget to do the
forward port. When the new master is released, months later, the issue is
going to regress.
Now, of course one can commit to master and forget to backport by the same
mechanics. It's still bad,
but you get feedback right away that it happened, and if you don't, well at
least the fix is going to survive in the future.
A second rationale is side effects. Again, in an ideal world, making a bug
fix is a simple, isolated activity.
But in practice, it happens that it's convoluted, sometimes it's large and
scary, let alone the cases in which
you are sure nothing else is affected and then.. it is anyways
Committing on master first allows other core developers to assess the issue
without risking it first.
I just made a large fix for a bug in GeoTools image mosaic for images with
heterogeneous CRSs,
it was a fix, but it was so big that I treated it as a feature, and let it
stew on master for a month
before risking a backport.
Just sharing my 2 cents, don't get mad at me :-p
On Thu, Jun 15, 2017 at 6:04 PM, Emanuele Tajariol <etj@anonymised.com>
wrote:
Ian, in GeoServer there are 2 stable branches + the master branch, so it's
good to have a starting point (master) and then move toward a single
direction (backward) for porting the fix.
In GN there are 2 active branches, so I guess any direction for porting is
good; anyway (@Maria) there is no info in the wiki page about how the fix
should be ported forward.
Emanuele
2017-06-15 15:26 GMT+02:00 María Arias de Reyna <delawen@anonymised.com>:
On Thu, Jun 15, 2017 at 3:24 PM, Ian Turton <ijturton@anonymised.com> wrote:
> Are you guys sure you want bug fixes to go to stable, wouldn't it be
> better
> to ug fix unstable (master) and back port to stable (released) branch.
> Other
> wise you will reacquire bugs when you make a new release from master?
Branches always go forwards, not backwards. Everything on stable will
go to unstable. So the bugfix will go to unstable. Things pushed to
unstable will not be cherry picked to stable (or shouldn't be).
Check out the vibrant tech community on one of the world's most
GeoNetwork-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
