[GeoNetwork-devel] Nightly builds failing
The nightly builds seem to be failing.
I know there are currently issues <https://status.github.com/&gt; with
github - is this what is causing the nightly builds to fail?
Thank you.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Nightly-builds-failing-tp5013602.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
do you have access to the nightly build server or do you only see the missing archives?
I know there are currently issues <https://status.github.com/> with
Thank you.
LogMeIn Central: Instant, anywhere, Remote PC access and management.
Stay in control, update software, and manage PCs from one command center
Diagnose problems and improve visibility into emerging IT issues
Automate, monitor and manage. Do more in less time with Central
http://p.sf.net/sfu/logmein12331_d2d
GeoNetwork-devel mailing list
No access to the server - just noticed that on the download page it is not
being updated.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Nightly-builds-failing-tp5013602p5013653.html
If someone wants to give me access I will check to see if I can fix the
issues.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Nightly-builds-failing-tp5013602p5013984.html
Hi Ian
I’m checking about the issue to solve it, seem related to geoserver submodule.
I’ll manage to create an account for you and send you in private mail.
Jose García
issues.
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi
Nightly builds are working ok, seem some issues with wrong submodules references caused the problems. Thanks Jesse for support on this.
I just created a nightly build for trunk and 2.8.x to have an updated build of both.
Jose García
On Mon, Nov 5, 2012 at 1:05 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Ian
Jose García
issues.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
