Lately I have had many problems with maven repositories in geoNetwork.
This one is for the latest develop branch. Someone else having
problems?
I tried with several maven 3.x.x versions, but all shows the same. We
are using maven3 now, right?
The code is a clean checkout:
$ git status
# On branch develop
nothing to commit (working directory clean)
$ git remote -v
origin https://github.com/geonetwork/core-geonetwork.git (fetch)
origin https://github.com/geonetwork/core-geonetwork.git (push)
$ git branch
* develop
$ mvn clean package install -Dmaven.test.skip -XX:MaxPermSize=512m
Apache Maven 3.2.1 (ea8b2b07643dbb1b84b6d16e1f08391b666bc1e9;
2014-02-14T18:37:52+01:00)
Maven home: /opt/apache-maven-3.2.1
Java version: 1.6.0_27, vendor: Sun Microsystems Inc.
Java home: /usr/lib/jvm/java-6-openjdk-amd64/jre
Default locale: es_ES, platform encoding: UTF-8
OS name: "linux", version: "3.2.0-4-amd64", arch: "amd64", family: "unix"
[INFO] Error stacktraces are turned on.
[DEBUG] Reading global settings from /opt/apache-maven-3.2.1/conf/settings.xml
[DEBUG] Reading user settings from /home/delawen/.m2/settings.xml
[DEBUG] Using local repository at /home/delawen/.m2/repository
[DEBUG] Using manager EnhancedLocalRepositoryManager with priority
10.0 for /home/delawen/.m2/repository
[INFO] Scanning for projects...
[DEBUG] Extension realms for project
org.geonetwork-opensource:geonetwork:pom:2.11.0-SNAPSHOT: (none)
[DEBUG] Looking up lifecyle mappings for packaging pom from
ClassRealm[plexus.core, parent: null]
org.geonetwork-opensource:common:jar:2.11.0-SNAPSHOT: (none)
[DEBUG] Looking up lifecyle mappings for packaging jar from
org.geonetwork-opensource:cachingxslt:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:jeeves:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:dummy-api:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:web-ui:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:web-ui-docs:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:domain:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:oaipmh:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:core:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:csw-server:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:harvesters:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:health-monitor:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:services:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:geonetwork-client:jar:2.11.0-SNAPSHOT:
(none)
org.geonetwork-opensource:wro4j:jar:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:web-app:war:2.11.0-SNAPSHOT: (none)
[DEBUG] Looking up lifecyle mappings for packaging war from
org.geonetwork-opensource:e2e-tests:pom:2.11.0-SNAPSHOT: (none)
org.geonetwork-opensource:geoserver:war:2.11.0-SNAPSHOT: (none)
[WARNING]
[WARNING] Some problems were encountered while building the effective
model for org.geonetwork-opensource:common:jar:2.11.0-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for
org.apache.maven.plugins:maven-compiler-plugin is missing. @
org.geonetwork-opensource:geonetwork:2.11.0-SNAPSHOT,
/var/git/geonetwork3/pom.xml, line 246, column 15
org.codehaus.cargo:cargo-maven2-plugin is missing. @
/var/git/geonetwork3/pom.xml, line 268, column 15
[WARNING] The expression ${version} is deprecated. Please use
${project.version} instead.
[WARNING]
model for org.geonetwork-opensource:cachingxslt:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:jeeves:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:dummy-api:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:web-ui:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:web-ui-docs:jar:2.11.0-SNAPSHOT
org.codehaus.mojo:xml-maven-plugin is missing. @ line 41, column 15
[WARNING]
model for org.geonetwork-opensource:domain:jar:2.11.0-SNAPSHOT
org.codehaus.mojo:build-helper-maven-plugin is missing. @ line 116,
column 21
org.apache.maven.plugins:maven-jar-plugin is missing. @ line 85,
column 21
[WARNING]
model for org.geonetwork-opensource:oaipmh:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:core:jar:2.11.0-SNAPSHOT
org.apache.maven.plugins:maven-jar-plugin is missing. @ line 376,
column 21
[WARNING]
model for org.geonetwork-opensource:csw-server:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:harvesters:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:health-monitor:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:services:jar:2.11.0-SNAPSHOT
org.apache.maven.plugins:maven-jar-plugin is missing. @ line 68,
column 21
[WARNING]
model for org.geonetwork-opensource:geonetwork-client:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:wro4j:jar:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:web-app:war:2.11.0-SNAPSHOT
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)'
must be unique: org.slf4j:slf4j-log4j12:jar -> duplicate declaration
of version (?) @ line 261, column 17
[WARNING]
model for org.geonetwork-opensource:e2e-tests:pom:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:geoserver:war:2.11.0-SNAPSHOT
[WARNING]
model for org.geonetwork-opensource:geonetwork:pom:2.11.0-SNAPSHOT
org.apache.maven.plugins:maven-compiler-plugin is missing. @ line 246,
column 15
org.codehaus.cargo:cargo-maven2-plugin is missing. @ line 268, column
15
[WARNING]
[WARNING] It is highly recommended to fix these problems because they
threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer
support building such malformed projects.
[WARNING]
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoNetwork opensource
[INFO] common utils
[INFO] Caching xslt module
[INFO] GeoNetwork domain
[INFO] Jeeves modules
[INFO] ArcSDE module (dummy-api)
[INFO] GeoNetwork user interface module
[INFO] JS API & Service documentation
[INFO] Oaipmh modules
[INFO] GeoNetwork web client module
[INFO] GeoNetwork core
[INFO] GeoNetwork CSW server
[INFO] GeoNetwork health monitor
[INFO] GeoNetwork harvesters
[INFO] GeoNetwork services
[INFO] Geonetwork Web Resources 4 Java
[INFO] GeoNetwork Web module
[INFO] GeoNetwork E2E Javascript Tests
[INFO] GeoServer module
[DEBUG] Resolving plugin version for
[DEBUG] Could not find metadata
org.apache.maven.plugins:maven-compiler-plugin/maven-metadata.xml in
local (/home/delawen/.m2/repository)
[DEBUG] Failure to find
http://oss.sonatype.org/content/repositories/github-releases was
cached in the local repository, resolution will not be reattempted
until the update interval of oss.sonatype.org-github-releases has
elapsed or updates are forced
[DEBUG] Skipped remote update check for
org.apache.maven.plugins:maven-compiler-plugin/maven-metadata.xml,
locally cached metadata up-to-date.
[DEBUG] Resolved plugin version for
org.apache.maven.plugins:maven-compiler-plugin to 3.1 from repository
central (http://repo.maven.apache.org/maven2, releases)
[DEBUG] Resolving plugin version for org.codehaus.cargo:cargo-maven2-plugin
org.codehaus.cargo:cargo-maven2-plugin/maven-metadata.xml in local
org.codehaus.cargo:cargo-maven2-plugin/maven-metadata.xml, locally
org.codehaus.cargo:cargo-maven2-plugin to 1.4.8 from repository
[DEBUG] Resolving plugin prefix X from [org.apache.maven.plugins,
org.codehaus.mojo]
org.apache.maven.plugins/maven-metadata.xml in local
org.apache.maven.plugins/maven-metadata.xml, locally cached metadata
up-to-date.
up-to-date.
[DEBUG] Could not find metadata org.codehaus.mojo/maven-metadata.xml
in local (/home/delawen/.m2/repository)
org.codehaus.mojo/maven-metadata.xml, locally cached metadata
up-to-date.
[DEBUG] Using connector WagonRepositoryConnector with priority 0.0 for
Downloading: http://oss.sonatype.org/content/repositories/github-releases/org/codehaus/mojo/maven-metadata.xml
[DEBUG] Writing tracking file
/home/delawen/.m2/repository/org/codehaus/mojo/resolver-status.properties
in oss.sonatype.org-github-releases
(http://oss.sonatype.org/content/repositories/github-releases)
org.codehaus.mojo/maven-metadata.xml, already updated during this
session.
[DEBUG] Failure to find org.codehaus.mojo/maven-metadata.xml in
Downloading: http://repo.maven.apache.org/maven2/org/codehaus/mojo/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/github-releases/org/apache/maven/plugins/maven-metadata.xml
/home/delawen/.m2/repository/org/apache/maven/plugins/resolver-status.properties
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-metadata.xml
(13 KB at 23.2 KB/sec)
Downloaded: http://repo.maven.apache.org/maven2/org/codehaus/mojo/maven-metadata.xml
(22 KB at 37.9 KB/sec)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoNetwork opensource ............................. SKIPPED
[INFO] common utils ...................................... SKIPPED
[INFO] Caching xslt module ............................... SKIPPED
[INFO] GeoNetwork domain ................................. SKIPPED
[INFO] Jeeves modules .................................... SKIPPED
[INFO] ArcSDE module (dummy-api) ......................... SKIPPED
[INFO] GeoNetwork user interface module .................. SKIPPED
[INFO] JS API & Service documentation .................... SKIPPED
[INFO] Oaipmh modules .................................... SKIPPED
[INFO] GeoNetwork web client module ...................... SKIPPED
[INFO] GeoNetwork core ................................... SKIPPED
[INFO] GeoNetwork CSW server ............................. SKIPPED
[INFO] GeoNetwork health monitor ......................... SKIPPED
[INFO] GeoNetwork harvesters ............................. SKIPPED
[INFO] GeoNetwork services ............................... SKIPPED
[INFO] Geonetwork Web Resources 4 Java ................... SKIPPED
[INFO] GeoNetwork Web module ............................. SKIPPED
[INFO] GeoNetwork E2E Javascript Tests ................... SKIPPED
[INFO] GeoServer module .................................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3.098 s
[INFO] Finished at: 2014-04-11T09:08:39+01:00
[INFO] Final Memory: 13M/148M
[ERROR] No plugin found for prefix 'X' in the current project and in
the plugin groups [org.apache.maven.plugins, org.codehaus.mojo]
available from the repositories [local (/home/delawen/.m2/repository),
(http://oss.sonatype.org/content/repositories/github-releases),
central (http://repo.maven.apache.org/maven2)] -> [Help 1]
org.apache.maven.plugin.prefix.NoPluginFoundForPrefixException: No
plugin found for prefix 'X' in the current project and in the plugin
groups [org.apache.maven.plugins, org.codehaus.mojo] available from
at org.apache.maven.plugin.prefix.internal.DefaultPluginPrefixResolver.resolve(DefaultPluginPrefixResolver.java:93)
at org.apache.maven.lifecycle.internal.MojoDescriptorCreator.findPluginForPrefix(MojoDescriptorCreator.java:260)
at org.apache.maven.lifecycle.internal.MojoDescriptorCreator.getMojoDescriptor(MojoDescriptorCreator.java:220)
at org.apache.maven.lifecycle.internal.DefaultLifecycleTaskSegmentCalculator.calculateTaskSegments(DefaultLifecycleTaskSegmentCalculator.java:106)
at org.apache.maven.lifecycle.internal.DefaultLifecycleTaskSegmentCalculator.calculateTaskSegments(DefaultLifecycleTaskSegmentCalculator.java:86)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:85)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:361)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:155)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:584)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:213)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:157)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions,
please read the following articles:
[ERROR] [Help 1]
http://cwiki.apache.org/confluence/display/MAVEN/NoPluginFoundForPrefixException
