[GeoNetwork-devel] OSGeoLive GeoNetwork update to 3.12.x
Dear all,
I am reaching out because the GeoNetwork version installed in OSGeoLive is still 3.2.x
Can someone please update the OSGeoLive installer for a more recent (3.12.x) release?
https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_geonetwork.sh
Best regards,
Angelos
Angelos Tzotsos, PhD
President
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
If there is no volunteer to bring GeoNetwork to a later version, I will give it a try and report back.
Best,
Angelos
On 1/7/23 17:42, Angelos Tzotsos wrote:
Dear all,
Best regards,
Angelos
President
Hello Angelos,
I can try, but I’m not sure about how to do it. Any documentation available about how to update OSGeoLive?
Best regards,
Juan Luis.
---- On Fri, 17 Mar 2023 10:10:04 +0100 Angelos Tzotsos via GeoNetwork-devel geonetwork-devel@anonymised.coms.sourceforge.net wrote —
Best,
Angelos
Dear all,
(3.12.x) release?
Best regards,
Angelos
President
GeoNetwork-devel mailing list
GeoNetwork-devel@anonymised.comurceforge.net
Hi Juan Luis,
For the OSGeoLive we run the following installer when creating the iso:
Configuration files are here:
https://github.com/OSGeo/OSGeoLive/tree/master/app-conf/geonetwork
Best regards,
Angelos
On 3/17/23 11:36, Juan Luis Rodriguez Ponce wrote:
Hello Angelos,
I can try, but I'm not sure about how to do it. Any documentation available about how to update OSGeoLive?
Best regards,
Juan Luis.
---- On Fri, 17 Mar 2023 10:10:04 +0100 Angelos Tzotsos via GeoNetwork-devel <geonetwork-devel@lists.sourceforge.net> wrote ---
  Best,
Angelos
Dear all,
(3.12.x) release?
Best regards,
Angelos
President
Is Java 8 installed in the VM? If it is, what’s the path I can use as JAVA_HOME for GN>
Best regards,
Juan Luis.
E-mail: juanluisrp@anonymised.com
https://www.geocat.net
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Fri, 17 Mar 2023 16:35:33 +0100 Angelos Tzotsos gcpp.kalxas@anonymised.com wrote —
Hi Juan Luis,
Best regards,
Angelos
Hello Angelos,
Best regards,
Juan Luis.
---- On Fri, 17 Mar 2023 10:10:04 +0100 Angelos Tzotsos via GeoNetwork-devel <geonetwork-devel@lists.sourceforge.net> wrote —
Best,
Angelos
Dear all,
(3.12.x) release?
Best regards,
Angelos
President
The default Java in OSGeoLive is 8. We have patched the upstream java-common debian package (Java 11 was default in Ubuntu Jammy):
https://launchpadlibrarian.net/604013449/java-common_0.72build2_0.72build2+osgeolive0.diff.gz
The Java path is
/usr/lib/jvm/default-java/bin/java
Best regards,
Angelos
On 3/21/23 13:24, Juan Luis Rodriguez Ponce wrote:
Is Java 8 installed in the VM? If it is, what's the path I can use as JAVA_HOME for GN>
Best regards,
Juan Luis.
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Fri, 17 Mar 2023 16:35:33 +0100 Angelos Tzotsos <gcpp.kalxas@anonymised.com> wrote ---
Hi Juan Luis,
  Best regards,
Angelos
Hello Angelos,
Best regards,
Juan Luis.
---- On Fri, 17 Mar 2023 10:10:04 +0100 Angelos Tzotsos via GeoNetwork-devel <mailto:geonetwork-devel@lists.sourceforge.net> wrote ---
Best,
Angelos
Dear all,
(3.12.x) release?
Best regards,
Angelos
President
