[GeoNetwork-devel] persistency of fileidentifiers
We have recently changed to using version 3.0 of GeoNetwork and all the records that come via WAF nodes have had their fileidentifiers changed. Having searched the posts and tickets this would seem to be a longstanding quirk. Does anyone have any advice how to circumvent this as the metadata standard we use explicitly states that fileidentifiers should not change.
Thank you
Gaynor
Dr Gaynor Evans
Marine Environmental Data and Information Network | Joseph Proudman Building | 6 Brownlow Street | Liverpool L3 5DA | +44 (0)151 795 4881
cid:5512E7570583364BA69EE75D7F35C364@anonymised.com
Hi
Was it working fine in 2.x versions?
Checking the commit history of the webdav package for 3.4.x version: https://github.com/geonetwork/core-geonetwork/commits/3.4.x/harvesters/src/main/java/org/fao/geonet/kernel/harvest/harvester/webdav, I don’t see any commit related to changes in the uuid policy used, unless could be committed as part of other change and not documented properly in the commit.
Jose García
(attachments)
On Fri, Feb 9, 2018 at 4:22 PM, Evans, Gaynor <gaev@anonymised.com1163…> wrote:
Thank you
Gaynor
Dr Gaynor Evans
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
GeoNetwork-devel mailing list
GeoNetwork-devel@…537…sourceforge.net
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
