[GeoNetwork-devel] personalized schema plugin error
Hi GN experts,
I have been creating a personalized metadata schema to be loaded into GN
trunk. I am using the GN developers manual as my main guide. I have
created/edited each XML, XSD, and XSL files which are needed to create a new
plugin schema. But now when I run GN and try to access it, an error shows;
THE REQUESTED OPERATION COULD NOT BE PERFORMED.
TransformerConfigurationException : Failed to compile stylesheet. 6 errors
detected.
I have checked the log file but it only shows:
2012-03-29 11:39:11,586 INFO [jeeves.service] - -> dispatching to output
for : home
2012-03-29 11:39:12,492 INFO [jeeves.service] - -> transforming with
stylesheet : C:\GeoNetwork_TRUNK\web\geonetwork/xsl/home.xsl
2012-03-29 11:39:12,711 INFO [jeeves.service] - -> end transformation
for : home
2012-03-29 11:39:12,711 INFO [jeeves.service] - -> output ended for :
home
2012-03-29 11:39:12,711 INFO [jeeves.service] - -> dispatch ended for :
home
2012-03-29 11:39:12,726 INFO [jeeves.request] -
2012-03-29 11:39:12,742 INFO [jeeves.request] - HTML Request (from
127.0.0.1) : /geonetwork/srv/en/main.home
2012-03-29 11:39:12,742 DEBUG [jeeves.request] - Method : GET
2012-03-29 11:39:12,742 DEBUG [jeeves.request] - Content type : null
2012-03-29 11:39:12,742 DEBUG [jeeves.request] - Accept :
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2012-03-29 11:39:12,742 DEBUG [jeeves.request] - Session id is
wf309yr30xwt1bt0owcb3tsya
2012-03-29 11:39:12,742 INFO [jeeves.service] - Dispatching : main.home
2012-03-29 11:39:12,742 DEBUG [jeeves.service] - -> no input parameters
2012-03-29 11:39:12,742 INFO [jeeves.service] - -> dispatching to output
for : main.home
2012-03-29 11:39:13,101 INFO [jeeves.service] - -> transforming with
stylesheet : C:\GeoNetwork_TRUNK\web\geonetwork/xsl/main-page.xsl
2012-03-29 11:39:14,211 ERROR [jeeves.service] - -> exception during
transformation for : main.home
2012-03-29 11:39:14,211 ERROR [jeeves.service] - -> (C) stylesheet :
2012-03-29 11:39:14,211 ERROR [jeeves.service] - -> (C) message :
Failed to compile stylesheet. 6 errors detected.
2012-03-29 11:39:14,211 ERROR [jeeves.service] - -> (C) exception :
2012-03-29 11:39:14,211 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
  <message>Failed to compile stylesheet. 6 errors detected.</message>
  <class>TransformerConfigurationException</class>
  <stack>
    <at class="net.sf.saxon.PreparedStylesheet"
file="PreparedStylesheet.java" line="176" method="prepare" />
    <at class="net.sf.saxon.TransformerFactoryImpl"
file="TransformerFactoryImpl.java" line="139" method="newTemplates" />
    <at class="de.fzi.dbs.xml.transform.CachingTransformerFactory"
file="CachingTransformerFactory.java" line="127" method="newTransformer" />
file="CachingTransformerFactory.java" line="82" method="newTransformer" />
    <at class="jeeves.utils.Xml" file="Xml.java" line="467"
method="transform" />
    <at class="jeeves.utils.Xml" file="Xml.java" line="393"
    <at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="718" method="dispatchOutput" />
file="ServiceManager.java" line="414" method="dispatch" />
    <at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="719" method="dispatch" />
    <at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="196" method="execute" />
  </stack>
  <request>
    <language>en</language>
    <service>main.home</service>
  </request>
  <response />
</error>
2012-03-29 11:39:14,211 INFO [jeeves.service] - -> dispatching to error
for : main.home
2012-03-29 11:39:14,242 INFO [jeeves.service] - -> transforming with
stylesheet : C:\GeoNetwork_TRUNK\web\geonetwork/xsl/error.xsl
2012-03-29 11:39:14,304 INFO [jeeves.service] - -> end error
2012-03-29 11:39:14,320 INFO [jeeves.service] - -> error ended for :
main.home
which is not very informative. Has anyone faced this problem before? if
yes..maybe you could share the solution to this?
Or maybe how can I find the error descriptions, meaning which files has
caused these errors? or a detailed error log file.
Thank you beforehand!!
Ciao,
Tania
View this message in context: http://osgeo-org.1560.n6.nabble.com/personalized-schema-plugin-error-tp4667315p4667315.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
