Yep - The oasis catalog in WEB-INF/oasis-catalog.xml remaps that url to the local file ../xml/validation/schemaPlugins/schema-ident.xsd.
Giving the schemas we use in GN to validate config files a home outside of the installation is one way to make them available to anyone who might want to access them - the intention was/is to create this dir for that reason but on the downside its one extra thing to maintain.
Simon
________________________________________
Sent: Wednesday, 11 July 2012 9:45 PM
To: Jose Garcia
Cc: Devel geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Plugin profiles: schemaLocation for schema-ident.xsd
I believe that the Xml Resolver is supposed to resolve that correctly.
Jesse
On Wed, Jul 11, 2012 at 1:19 PM, Jose Garcia <jose.garcia@anonymised.com<mailto:jose.garcia@anonymised.com>> wrote:
Hi
In schema profiles the file schema-ident.xml has this:
xsi:schemaLocation="http://geonetwork-opensource.org/schemas/schema-ident/schema-ident.xsd"
but that URL doesn't exists. The xsd file is local to GeoNetwork installation: xml/validation/schemaPlugins/schema-ident.xsd
Should not be better to use local path in schemaLocation (or publish the xsd online)?
If using relative paths, no clear with new data directory structure what would be the correct relative path to xsd.
Thanks and regards,
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net/> for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
GeoNetwork-devel@lists.sourceforge.net<mailto:GeoNetwork-devel@anonymised.comforge.net>
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
