[GeoNetwork-devel] port 61616 already in use
Hello, install geonetwork 3.2 in Ubuntu 16.04, with 8,032 Tomcat and Java 1.8, but does not start me and I can not solve it, ubuntu is newly installed. The geonetwork.log pulls me follows:
2016-10-18 16:39:09,964 WARN [jeeves.config.springutil.JeevesApplicationContext] - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘org.apache.activemq.xbean.XBeanBrokerService#0’: Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use
2016-10-18 16:39:10,040 FATAL [jeeves.engine] - Raised exception during init
2016-10-18 16:39:10,041 FATAL [jeeves.engine] - Exception : org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘org.apache.activemq.xbean.XBeanBrokerService#0’: Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use
2016-10-18 16:39:10,041 FATAL [jeeves.engine] - Message : Error creating bean with name ‘org.apache.activemq.xbean.XBeanBrokerService#0’: Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use
2016-10-18 16:39:10,058 FATAL [jeeves.engine] - Stack : org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘org.apache.activemq.xbean.XBeanBrokerService#0’: Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessBeforeInitialization(InitDestroyAnnotationBeanPostProcessor.java:136)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:408)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1570)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:772)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:839)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:538)
at jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:97)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4812)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5255)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1293)
at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:666)
at org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:217)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
at org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:136)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:614)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1500)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1456)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use
at org.apache.activemq.util.IOExceptionSupport.create(IOExceptionSupport.java:33)
at org.apache.activemq.transport.tcp.TcpTransportServer.bind(TcpTransportServer.java:138)
at org.apache.activemq.transport.tcp.TcpTransportFactory.doBind(TcpTransportFactory.java:60)
at org.apache.activemq.transport.TransportFactory.bind(TransportFactory.java:131)
at org.apache.activemq.broker.TransportConnector.createTransportServer(TransportConnector.java:329)
at org.apache.activemq.broker.TransportConnector.getServer(TransportConnector.java:155)
at org.apache.activemq.broker.TransportConnector.start(TransportConnector.java:220)
at org.apache.activemq.broker.BrokerService.startTransportConnector(BrokerService.java:2330)
at org.apache.activemq.broker.BrokerService.startAllConnectors(BrokerService.java:2243)
at org.apache.activemq.broker.BrokerService.start(BrokerService.java:551)
at org.apache.activemq.broker.BrokerService.autoStart(BrokerService.java:494)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleElement.invoke(InitDestroyAnnotationBeanPostProcessor.java:354)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleMetadata.invokeInitMethods(InitDestroyAnnotationBeanPostProcessor.java:305)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessBeforeInitialization(InitDestroyAnnotationBeanPostProcessor.java:133)
… 47 more
Caused by: java.net.BindException: Address already in use
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:387)
at java.net.ServerSocket.bind(ServerSocket.java:375)
at java.net.ServerSocket.(ServerSocket.java:237)
at javax.net.DefaultServerSocketFactory.createServerSocket(ServerSocketFactory.java:231)
at org.apache.activemq.transport.tcp.TcpTransportServer.bind(TcpTransportServer.java:134)
… 63 more
Thanks for any help you can provide me to fix it.
Sorry for my English
Regards
