[GeoNetwork-devel] preformetted template doesn't work
The preformatted template in metadata.xsl doesn’t work for text areas. Unix can only see LF and Windows can only see CR. To fix I did this, maybe someone else has a better fix.
<xsl:template name=“preformatted”>
<xsl:param name=“text”/>
xsl:choose
<xsl:when test=“contains($text,’ ')”>
<xsl:value-of select=“substring-before($text,’ ')”/>
<xsl:call-template name=“preformatted”>
<xsl:with-param name=“text” select=“substring-after($text,’ ')”/>
</xsl:call-template>
</xsl:when>
</xsl:when>
</xsl:when>
xsl:otherwise
<xsl:value-of select=“$text”/>
</xsl:otherwise>
</xsl:choose>
</xsl:template>
Kevin Gunn
Software Engineer
Australian Institute of Marine Science
Ph: (07) 47534305
Fax: (07) 4772 5852
E-mail: k.gunn@anonymised.com
The information contained in this communication is for the use of the |
individual or entity to whom it is addressed, and may contain |
information which is the subject of legal privilege and/or copyright. |
If you have received this communication in error, please notify the |
sender by return E-Mail and delete the transmission, together with any |
attachments, from your system. Thank you. |
sender by return email and delete the transmission, together with any
