Dear all,
I have a big problem in adding a new harvester.
Unfortunately I couldn’t fine any up-to-date guideline for how to add a new harvester to GN. The only one which I found is the developer manual for the release 2.10.4-0. and apparently this document is not valid.
I want to add a separate OGC SOS harvester (I know that GN has already one for OGC web services) which harvest describesensors and not only getcapabilities.
I did test alot of things and these are the final steps I made:
I added the Java code in a package inside org.fao.geonet.kernel.harvest.harvester.ogcsos which contains OgcSOSHarvester.java and OgcSoSParams.java (and also Harvester.java).
I added one line to haresters/src/main/resources/config-spring-geonetwork with identical bean ID = ogcsos.
I added the transformation stylesheet in web/src/main/webapp/xsl/xml/harvesting/ogcsos.xml. [Its name must match the string used for the harvesting type.]
I added the ogcsos.js and ogcsos.html in the folder web-ui/src/main/resources/catalog/templates/admin/harvest/type.
** I am working with the version 3.4.2.
What I receive is only in the harvester webpage, from the dropdown I have the name of my OGC SOS but by click on it it does not call any template. What else do I need to check?
In the old manual it refers to harvesting.xml file. Where is this file located in my GN version?
What is the harvester setting table? where can i find this?
Many thanks in advance for your advice
Mani
