Hello,
I’m trying to run GeoNetwork in Ubuntu Server 17.10 but have had some issues. I hope someone here can give me insights in what modifications I need to do.
I’m trying to run it by having geonetwork.war in the /var/lib/tomcat8/webapps directory but when I try to deploy it using Tomcat Web Application Manager I get a:
FAIL - Application at context path [/geonetwork] could not be started
I thought the problem was due to the privileges of the /var/lib/tomcat8/ folder but after changing it to 777 I still can’t deploy the .war.
I’m using JVM version 1.8.0_151-b12 by Oracle.
Here is the catalina.out logfile related to my last attempt to deploy the geonetwork.war :
11-Jan-2018 14:54:25.488 INFO [http-nio-8082-exec-12] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
11-Jan-2018 14:54:25.491 INFO [http-nio-8082-exec-12] org.apache.catalina.core.ApplicationContext.log No Spring WebApplicationInitializer types detected on classpath
2018-01-11 14:54:26,258 WARN [jeeves.config.springutil.JeevesApplicationContext] - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘org.apache.activemq.xbean.XBeanBrokerService#0’: Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use (Bind failed)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessBeforeInitialization(InitDestroyAnnotationBeanPostProcessor.java:136)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:408)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1570)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:772)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:839)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:538)
at jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:97)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4745)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5207)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1309)
at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:665)
at org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:211)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:661)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:136)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:595)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:650)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:799)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use (Bind failed)
at org.apache.activemq.util.IOExceptionSupport.create(IOExceptionSupport.java:33)
at org.apache.activemq.transport.tcp.TcpTransportServer.bind(TcpTransportServer.java:138)
at org.apache.activemq.transport.tcp.TcpTransportFactory.doBind(TcpTransportFactory.java:60)
at org.apache.activemq.transport.TransportFactory.bind(TransportFactory.java:131)
at org.apache.activemq.broker.TransportConnector.createTransportServer(TransportConnector.java:329)
at org.apache.activemq.broker.TransportConnector.getServer(TransportConnector.java:155)
at org.apache.activemq.broker.TransportConnector.start(TransportConnector.java:220)
at org.apache.activemq.broker.BrokerService.startTransportConnector(BrokerService.java:2330)
at org.apache.activemq.broker.BrokerService.startAllConnectors(BrokerService.java:2243)
at org.apache.activemq.broker.BrokerService.start(BrokerService.java:551)
at org.apache.activemq.broker.BrokerService.autoStart(BrokerService.java:494)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleElement.invoke(InitDestroyAnnotationBeanPostProcessor.java:354)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleMetadata.invokeInitMethods(InitDestroyAnnotationBeanPostProcessor.java:305)
at org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessBeforeInitialization(InitDestroyAnnotationBeanPostProcessor.java:133)
… 48 more
Caused by: java.net.BindException: Address already in use (Bind failed)
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:387)
at java.net.ServerSocket.bind(ServerSocket.java:375)
at java.net.ServerSocket.(ServerSocket.java:237)
at javax.net.DefaultServerSocketFactory.createServerSocket(ServerSocketFactory.java:231)
at org.apache.activemq.transport.tcp.TcpTransportServer.bind(TcpTransportServer.java:134)
… 64 more
2018-01-11 14:54:26,270 FATAL [jeeves.engine] - Raised exception during init
2018-01-11 14:54:26,270 FATAL [jeeves.engine] - Exception : org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘org.apache.activemq.xbean.XBeanBrokerService#0’: Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use (Bind failed)
2018-01-11 14:54:26,270 FATAL [jeeves.engine] - Message : Error creating bean with name ‘org.apache.activemq.xbean.XBeanBrokerService#0’: Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use (Bind failed)
2018-01-11 14:54:26,272 FATAL [jeeves.engine] - Stack : org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘org.apache.activemq.xbean.XBeanBrokerService#0’: Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use (Bind failed)
… 48 more
… 64 more
11-Jan-2018 14:54:26.272 SEVERE [http-nio-8082-exec-12] org.apache.catalina.core.StandardContext.listenerStart Exception sending context initialized event to listener instance of class [jeeves.config.springutil.JeevesContextLoaderListener]
java.lang.RuntimeException: Exception raised
at jeeves.server.JeevesEngine.handleStartupError(JeevesEngine.java:125)
at jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:145)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘org.apache.activemq.xbean.XBeanBrokerService#0’: Invocation of init method failed; nested exception is java.io.IOException: Failed to bind to server socket: tcp://localhost:61616 due to: java.net.BindException: Address already in use (Bind failed)
… 36 more
… 48 more
… 64 more
11-Jan-2018 14:54:26.272 SEVERE [http-nio-8082-exec-12] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
11-Jan-2018 14:54:26.272 SEVERE [http-nio-8082-exec-12] org.apache.catalina.core.StandardContext.startInternal Context [/geonetwork] startup failed due to previous errors
11-Jan-2018 14:54:26.771 SEVERE [http-nio-8082-exec-12] org.apache.catalina.core.StandardContext.listenerStop Exception sending context destroyed event to listener instance of class [jeeves.config.springutil.JeevesContextLoaderListener]
java.lang.NullPointerException
at jeeves.config.springutil.JeevesContextLoaderListener.contextDestroyed(JeevesContextLoaderListener.java:161)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4792)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5429)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:226)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154)
11-Jan-2018 14:54:26.773 WARNING [http-nio-8082-exec-12] org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The web application [geonetwork] appears to have started a thread named [ElementEventQueue.QProcessor-1] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
java.lang.Object.wait(Native Method)
java.lang.Object.wait(Object.java:502)
org.apache.jcs.engine.control.event.ElementEventQueue.take(ElementEventQueue.java:181)
org.apache.jcs.engine.control.event.ElementEventQueue.access$300(ElementEventQueue.java:35)
org.apache.jcs.engine.control.event.ElementEventQueue$QProcessor.run(ElementEventQueue.java:245)
