Yep - definitely familiar with that
The algorithm might need a bit more work then as we have different versions of this profile and would need to check the profile and version numbers.
Cheers and thanks,
Simon
____________ ____________________________
From: Stephen M Richard [steve.richard@anonymised.com]
Sent: Thursday, 4 February 2010 10:26 AM
To: Pigot, Simon (CMAR, Hobart)
Cc: GeoNetwork-devel@lists.sourceforge.net; dominic.owen@anonymised.com; wgrunberg@anonymised.com
Subject: Re: [GeoNetwork-devel] proposal for change to schema detection logic
Simon--
the MEST-Blue Net profile schema from the BlueNet GeoNetwork branch is
the exemplar we were looking at for a conformance level 2 profile, with
root element MD_Metadata with a different namespace URI
xmlns:mcp="http://bluenet3.antcrc.utas.edu.au/mcp" as served from
http://mest.ivec.org/geonetwork/srv/en/main.home. You're familiar with
this project, I believe?
Glad to hear you'd like to integrate into the trunk; we're still
debugging, but we'll keep you posted.
thanks
steve
On 2/3/2010 4:04 PM, Simon.Pigot@anonymised.com wrote:
Hi Stephen et al,
Thanks for the document and description - looks like it covers most of the stuff I know about in conformance level 1 - adding the appinfo stuff to the schema.xsd (ie. GN only, leaves base xsds untouched etc) seems like a good idea and workable - also should work for other schemas apart from ISO as well.
Do you have an example of a conformance level 2 profile (ie. root element known but its namespace uri is not the standard namespace uri)?
I'd like to integrate this into the trunk after testing it - we have a profile test case that would be nice to try out.
Cheers and thanks,
Simon
________________________________________
Sent: Thursday, 4 February 2010 5:13 AM
To: GeoNetwork-devel@lists.sourceforge.net; dominic.owen; Wolfgang Grunberg
Subject: [GeoNetwork-devel] proposal for change to schema detection logic
Dear Geonetwork team--
We are testing a modification of the GeoNetwork schema detection algorithm to use the ISO19139 metadataStandardName and version information to identify use of a conformance level one profile. We would like to see this logic added to the trunk build.
The logic will not break the currently used approach; it will add some additional tests, and its use will depend on adding an annotation/appinfo element in the schema.xsd schema that is in the root of each profile configuration directory in %geonetworkroot%/web/geonetwork/xml/schemas. The design would allow for profiles of other base metadata schema as well, if the profile provides a means of self identification. The attached document describes the logic in more detail, and a flow chart for the logic is shown below.
Dominic Owen, who has been posting some here recently, is working with our project (USGIN http://lab.usgin.org) is doing the programming, currently working in a local sandbox.
We will research the procedure for a formal request, but wanted to get the idea out for consideration now..
thanks
steve
[cid:part1.04080002.09050108@anonymised.com]
Stephen M. Richard
Section Chief, Geoinformatics
Arizona Geological Survey
416 W. Congress St., #100
Tucson, Arizona, 85701 USA
Phone:
Office: (520) 209-4127
Reception: (520) 770-3500
FAX: (520) 770-3505
email: steve.richard@anonymised.com<mailto:steve.richard@anonymised.com>
Stephen M. Richard
Phone:
FAX: (520) 770-3505
