[GeoNetwork-devel] Proposal to remove the ISO19115-3 git submodule from 3.10.x branch and add it as part of the branch
Hi
Currently we have the ISO19115-3 schema in master as part of the branch and in 3.10.x still it’s a submodule.
This makes it difficult to cherry-pick commits from master involving changes to the ISO19115-3 schema. Some of the changes involve only code in that schema, so are quite isolated, but other changes also affect other modules making the backports a bit more complicated.
Are there any concerns about removing the ISO19115-3 submodule from 3.10.x and managing it as part of the branch as in master.
Jose García
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
FIne for me Jose.
Francois
Le lun. 21 sept. 2020 à 11:21, Jose Garcia <jose.garcia@anonymised.com> a écrit :
Hi
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
GeoNetwork-devel mailing list
I think it is a great idea :slight_smile:
Any chance we could change the schema version to 3.10.x while we do this? It would help allowing things like https://github.com/GeoCat/experiment-hnap to build straight from the maven repository without having to build geonetwork locally.
Jody Garnett
Hi
Nice, Jody is going to manage this for the 3.10.x branch, removing the submodule and copying the code for iso19115-3 from GeoNetwork master branch as it has been getting updates after the submodule was abandoned.
Jose García
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Here is the PR for 3.10.x:
I also noted some changes to the README.md so there is a PR for master:
Jody Garnett
Reminder with this change I am reposting these instructions:
If you update with git pull you will get the following error:
From github.com:geonetwork/core-geonetwork
* branch master → FETCH_HEAD
= [up to date] master → upstream/master
error: The following untracked working tree files would be overwritten by merge:
schemas/iso19115-3.2018/ISO19115-3-2014-to-ISO19115-3-2018.xsl
schemas/iso19115-3.2018/ISO19139-to-ISO19115-3-2018.xsl
Here is how to update:
cd schemas
rm -r iso19115-3.2018
git pull
git checkout .
Jody Garnett
