[Geonetwork-devel] Re: GeoNetwork Assistance Request
Hi Steven,
your geonetwork installation was ok, as you can see from the setup.log.
Now, you need to start geonetwork so, open a terminal, go inside
geonetwork's bin directory and issue the command:
./start-geonetwork.sh
Now point firefox to localhost:8080/geonetwork to see geonetwork in action.
I have copied Jeroen because he can provide better infos (he is actually
running geonetwork on a mac).
Andrea,
My problem is that I don't know what to do after installation. I'm
missing something very fundamental, I believe. I've searched on the
CD and online and I can only find substantial instructions for other
platforms, but not Macintosh.
Here's my Mac system:
I assume I meet all the requirements, including the default Java
environment that comes with the full Mac OS installation:
Power Mac G5 2GHz (latest model), which is PPC (not Intel)
OS 10.4.6 (latest version with latest updates of all components)
Frameworks (OS X 'built in' Java Operating Environment = J2SE 5.0)
JavaApplicationLauncher:
   Version: 11.4.0
   Last Modified: 04/24/06 8:21 AM
JavaApplicationLauncherUI:
   Version: 10.0.2
   Last Modified: 04/06/06 9:55 AM
JavaCarbonSupport:
   Version: 10.0.2
JavaEmbedding:
   Version: 10.0.2
JavaScriptGlue:
   Version: 417
   Last Modified: 04/18/06 10:28 AM
JavaVM:
   Version: 11.4.0
Firefox 1.5.0.3
Safari 2.0.3
Here's what I've done so far:
1. Before receiving the install CD, I happened to visit the
GeoNetwork Opensource Community Website <http://193.43.36.138/&gt; and
joined as user "minta".
2. Later, I received the CD (2.0.2) and installed everything
necessary for the standalone for Macintosh. However, during the
install process, I registered it as "administrator" because that was
the default text in the fill-in box. Is that a problem for me?
3. Everything seems to have installed fine, with the occupied folder
"geonetwork_desktop" in my Applications folder, and the setup.log
reporting:
=== Setup started ===================================================
Creating McKoi data files in
'/Applications/geonetwork_desktop/web/WEB-INF/db/db.conf' ...
Starting McKoi server...
Ok, McKoi started.
Creating db schema...
Filling db tables...
    Filling table 'Metadata' with data file
'/Applications/geonetwork_desktop/setup/db/Metadata.ddf'
    Filling table 'Users' with data file
'/Applications/geonetwork_desktop/setup/db/Users.ddf'
    Filling table 'Groups' with data file
'/Applications/geonetwork_desktop/setup/db/Groups.ddf'
    Filling table 'UserGroups' with data file
'/Applications/geonetwork_desktop/setup/db/UserGroups.ddf'
    Filling table 'Operations' with data file
'/Applications/geonetwork_desktop/setup/db/Operations.ddf'
    Skipping table : Help
    Filling table 'Categories' with data file
'/Applications/geonetwork_desktop/setup/db/Categories.ddf'
    Filling table 'MetadataCateg' with data file
'/Applications/geonetwork_desktop/setup/db/MetadataCateg.ddf'
    Filling table 'OperationAllowed' with data file
'/Applications/geonetwork_desktop/setup/db/OperationAllowed.ddf'
Almost finished...
Disconnecting...
Stopping McKoi server...
Adding activator to config.xml...
=== Setup ended =====================================================
4. Here is where I don't know what to do next, although it's clear to
me for Windows. By the way, if I go to the web site using Firefox
(http://193.43.36.138/), this is what I see:
Thanks for any pointers,
Steve
>Hi Steven,
>these problems can be answered by me and Jeroen.
>What kind of problems do you have? When installing GeoNetwork
>see into the 'setup' folder to find logs: maybe you would be able
>to fix the problem.
>Let me know,
>Andrea
>> Andrea,
>> Please direct me to where I can ask a technical question about the
>> installation of GeoNetwork 2.0.2 on Mac OS X (10.4.6) with latest OS
>> X Java environment.
>> I have the CD (v.2.0.2), but cannot successfully implement the
>> "standalone" implementation.
>> Thank you,
>> Steven Minta
>> Ecological Consultant
>> UN FAO
