[GeoNetwork-devel] relaod4j dropin replacement for log4j 1.2 for 3.12 releases
I ran an experiment updating the 3.12.x branch to use reload4j https://github.com/geonetwork/core-geonetwork/pull/6896
The 3.12.x branch did not make the leap to Log4j 2.x API, and was just released again this week. The use of reload4j as a drop-in replacement for the log4j library allows the 3.12.x branch to be released using a supported/patched logging library.
The PR builds and starts up; but is not tested. I would like confirmation that the PSC figures this is a good idea before spending any further tie on this proposed change.
Jody Garnett
Hi Jody
To me seems a good idea to use a supported/patched logging library like reload4j which has the same API as log4j 1.2 as there are quite a few users still using GeoNetwork 3.12.
Jose García
Jose Garcia
E-mail: jose.garcia@anonymised.com
https://www.geocat.net
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- El Wed, 08 Mar 2023 20:30:56 +0100, Jody Garnett via GeoNetwork-devel geonetwork-devel@lists.sourceforge.net escribió ----
Jody Garnett
GeoNetwork-devel mailing list
GeoNetwork-devel@anonymised.comet
