[GeoNetwork-devel] Related document indexing eg. kml and wfs indexing
Hi list, this is more an experiment on how to index related documents
which could be referenced in a metadata records.
For example having a kml document or a related WFS services in the
distribution section, we could then try to retrieve the document (GML
or KML) and index them in the full text search criteria (ie. any) the
content of those remote document.
This will slow down the index process for sure but could be useful in some ways.
Attached a quick patch adding the feature to the index mechanism for
iso19139 records.
Any thoughts ? Any people working on that direction ?
Ciao.
Francois
(attachments)
wfs-and-kml-indexing.patch (3.77 KB)
Hi Thijs,
2009/9/25 Thijs Brentjens <lists@anonymised.com>:
Great idea. Could be very powerful! Just to get it right for me: this patch
indexes data directly (if referred to in a metadata record) and adds this
information to the metadata records to improve search results.
That the point.
Possible practical issue: for WFS, even if you're using maxFeatures (as in
the patch), still the indexes could grow quickly, so I think one does want
to use a relatively small amount of features for indexing.
True, an idea, could be also to remove all non-text fields which
sounds not really useful at first glance.
But if using just
a few features, maybe the data returned is not representative enough. So
there is some balance to find here (worth experimenting..). But still, I
think it improves matching search results to queries.
And in some cases, when data could change quickly in time, the indexes may
become outdated, possibly resulting incorrect search results.
True also, but the index is updated for a record, everytime somebody
look at it (due to popularity increase) and related documents will be
parsed again (maybe we should only update the popularity value in the
index but for the time being the full record is reindex).
But again:
this is just in very rare cases.. I think these are just minor issues;
things to find out if they really do occur. Do you have some results / demo
maybe?
Not really, just had a try with some WFS I know about.
And to enable this feature, maybe add an extra queryable as well? To search
on the data (only) or maybe disable searches on data somehow? Would that be
possible?
For that, we could create a specific field in the index; "any"
contains metadata full text info, another field to store data info.
Easy.
Maybe this field could be updated on a regular basis in a background task.
Thanks for the comments.
Francois.
best regards,
Thijs
ways.
iso19139 records.
Ciao.
Francois
Come build with us! The BlackBerry&reg; Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;
http://p.sf.net/sfu/devconf
GeoNetwork-devel mailing list
Hi All,
Looks good Francois - with regard to the WFS, the proposal crosses over with the proposal to harvest metadata from a WFS by converting features to ISO metadata fragments which can be linked into records (ComposedMetadata proposal in the list of proposals on http://trac.osgeo.org/geonetwork/proposals). I guess by comparison the composed metadata records harvested from WFS approach is an attempt to structure the info from the WFS rather than dump it directly into the index for free text search (both are valid approaches - composing the metadata records requires more work but permits targetted searching and because it uses a GN harvester & the xlink cache indexing is still speedy).
Would also be interesting to index content from attached document resources like pdf or doc files, maybe using the apache tika content analysis toolkit too? (Apache Tika – Apache Tika)
Simon
Francois Prunayre wrote:
Hi Thijs,
That the point.
But if using just
But again:
maybe?
possible?
Easy.
Francois.
best regards,
Thijs
ways.
iso19139 records.
Ciao.
Francois
Best Open Source Mac Front-Ends 2024
geonetwork-devel List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Apologies link is ComposedMetadataRecords – GeoNetwork opensource Developer website
________________________________________
Sent: Saturday, 26 September 2009 7:56 PM
To: Francois Prunayre
Cc: Devel geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Related document indexing eg. kml and wfs indexing
Hi All,
Simon
Hi Thijs,
That the point.
But if using just
But again:
maybe?
possible?
Easy.
Francois.
best regards,
Thijs
ways.
iso19139 records.
Ciao.
Francois
Hello all,
Just wanted to mention that this proposal is conceptually equivalent to
http://trac.osgeo.org/geonetwork/wiki/ComponentsAndComposites. We are definitely interested in participating…
Ted
On Sep 26, 2009, at 4:08 AM, Simon.Pigot@anonymised.com wrote:
Apologies link is http://trac.osgeo.org/geonetwork/wiki/ComposedMetadataRecords
To: Francois Prunayre ilto:geonetwork-devel@lists.sourceforge.net">geonetwork-devel@lists.sourceforge.net
Hi All,
http://trac.osgeo.org/geonetwork/proposals)). I guess by comparison the
Would also be in te from attached document
analysis toolkit too? (http://lucene.apache.org/tika/)
Simon
Hi Thijs,
That the point.
Possible practical issue: for WFS, even if you’re using maxFeatures (as in
But if using just
there is some balance to find here (worth experimenting…). But still, I
But again:
this is just in very rare cases… I think these are just minor issues;
maybe?
< br type=“cite”>
possible?
For that, we could create a specific field in the index; “any”
Easy.
Thanks for the co mm ockquote type=“cite”>Francois.
best regards,
Thijs
ways.
< /b e=“cite”>
iso19139 records.
Ciao.
Come build with us! The BlackBerry® Developer Conference in SF, CA
ahead of the curve. Join us from November 9-12, 2009. Register now!
ahead of the curve. Join us from November 9-12, 2009. Register n ow p://p.sf.net/sfu/devconf">http://p.sf.net/sfu/devconf
GeoNetwork OpenSource is maintai ne et/projects/geonetwork
==== Ted Habermann ===========================
Enterprise Data Systems Group Leader
NOAA, National Geophysical Data Center
V: 303.497.6472 F: 303.497.6513
“If you want to go quickly, go alone.
If you want to go far, go together”
Old Proverb
==== Ted.Habermann@anonymised.com ==================
(attachments)
Ted Habermann.vcf (390 Bytes)
Hi Ted,
Thanks - I think the proposal is at pains to point out that the idea of composed (or componentized or composite or even 'relational') metadata is not new :slight_smile: (is there anything new 'under the sun'?). I think we even discussed it on this group sometime ago using terms like 'woolly' to cover the vague ideas we were throwing around at the time. I'll add a link to ComponentsAndComposites proposal so this conceptual equivalence is clear and thanks for the memory jog!
There is an implementation of the composed metadata proposal for the case where the composed metadata records are created from fragments harvested out of a WFS and we're working on moving our THREDDS metadata harvester to use the same fragment based idea. Both are (and will continue for the time being) in the BlueNetMEST sandbox.
For the WFS harvesting we have been using deegree WFS as it has nice support for modelling database table relationships and server-side XML transformations using XSLT. I'd like to add a test case using GeoServer WFS which makes sense as GeoServer comes with GeoNetwork.
Very much like to develop our cooperation over this and other ideas we have discussed elsewhere.
Simon
Ted Habermann wrote:
Hello all,
ComponentsAndComposites – GeoNetwork opensource Developer website. We are definitely interested in participating...
Ted
On Sep 26, 2009, at 4:08 AM, Simon.Pigot@anonymised.com <mailto:Simon.Pigot@anonymised.com> wrote:
From: Simon Pigot [Simon.Pigot@anonymised.com <mailto:Simon.Pigot@anonymised.com>]
To: Francois! Prunayre ilto:geonetwork-devel@lists.sourceforge.net">geonetwork-devel@lists.sourceforge.net
Hi All,
http://trac.osgeo.org/geonetwork/proposals) <http://trac.osgeo.org/geonetwork/proposals)&gt;\. I guess by comparison the
Would als! o be inte from attached document
Simon
Hi Thijs,
2009/9/25 Thijs Brentjens <lists@anonymised.com <mailto:lists@anonymised.com>>:
That the point.
But if using just
But again:
maybe?
possible?
Easy.
Thanks for! the comm ockquote type="cite">Francois.
best regards,
Thijs
ways.
iso19139 records.
Ciao.
GeoNetwork-devel@lists.sourceforge.net <mailto:GeoNetwork-devel@lists.sourceforge.net>
ahead of the curve. Join us from November 9&#45;12, 2009. Reg! ister now p://p.sf.net/sfu/devconf">Best Open Source Mac Front-Ends 2024
GeoNetwork OpenSource is ! maintaine et/projects/geonetwork
   "If you want to go quickly, go alone.
   If you want to go far, go together"
   Old Proverb
==== Ted.Habermann@anonymised.com <mailto:Ted.Habermann@anonymised.com> ==================
Simon,
it has been awhile since we worked on this (too many things going on). I believe that we were working on the Citation > Contact > OnlineResurce chain of fragments. These three are all fragments (components) in the current tool we are using so it made sense to us. We are also very interested in DS_Series as a root for ISO metadata which makes MD/MI_Metadata a fragment. I think this is actually relevant to the WMS problem where a service with several layers may end up being represented as some sort of aggregate…
One thing that you point out in your proposal is the xlink resolver. This is going to be a critical and interesting bit. Also, how (if) the other elements of the xlink standard might be used. For example, we were thinking of xlink:role as a role for a CI_ResponsibleParty that was represented by the fragment. I be is being done in SML, but am not sure it is really copacetic.
Ted
On Sep 27, 2009, at 8:01 AM, Simon Pigot wrote:
Hi Ted,
Thanks - I think the proposal is at pains to point out that the idea of composed (or componentized or composite or even ‘relational’) metadata is not new :slight_smile: (is there anything new ‘under the sun’?). I think we even discussed it on this group sometime ago using terms like ‘woolly’ to cover the vague ideas we were throwing around at the time. I’ll add a link to ComponentsAndComposites proposal so this conceptual equivalence is clear and thanks for the memory jog!
There is an implementation of the composed metadata proposal for the case where the composed metadata records are created from fragments harvested out of a WFS and we’re working on moving our THREDDS metadata harvester to use the same fragment based idea. Both are (and w il eing) in the BlueNetMEST sandbox.
For the WFS harvesting we have been using deegree WFS as it has nice support for modelling database table relationships and server-side XML transformations using XSLT. I’d like to add a test case using GeoServer WFS which makes sense as GeoServer comes with GeoNetwork.
Simon
Hello all,
Ted
Hi All,
http://trac.osgeo.org/geonetwork/proposals) <http://trac.osgeo.org/geonetwork/proposals%29>. I guess by comparison the
metadata records requires more work bu t ng and
Simon
Hi Thijs,
That the point.
But if using just
True also, but t record, everytime somebody
But again:
maybe?
p
Easy.
Thanks for! the comm ockquote type=“cite”>Francois.
< ote>
best regards,
Thijs
ways.
iso19139 records.
Ciao.
ahead of the curve. Join us from November 9 er now!
< /b blockquote>
------------------------------------------------------------ – ckquote>
htt p: >
ahead of the curve. Join us from November 9-12, 2009. Reg! ister now p://p.sf.net/sfu/devconf">http://p.sf.net/sfu/devconf
blockquote type=“cite”>
Old Proverb
developing skills, take Bla ck to market and stay ahead of the curve. Join us from November 9-12, 2009. Register now!
[https://lists.sourceforge.net/lists/listinfo/geonetwork-devel](https://li
st
istinfo/geonetwork-devel)
If you want to go far, go toget he ld Proverb
(attachments)
Simon,
Ted
Hi Ted,
There is an implementation of the composed metadata proposal for the case where the composed metadata records are created from fragments harvested out of a WFS and we’re working on moving our THREDDS metadata harvester to use the same fragment based idea. Both are (a time being) in the BlueNetMEST sandbox.
Simon
If you want to go far, go t og sp;Old Proverb
(attachments)
