Thanks Francois - that was exactly the problem. My metadata has a hierarchy level of model. I wondered whether hierarchy level was the cause - but only tested the theory by changing it to series...
James
________________________________________
From: Francois Prunayre [fx.prunayre@anonymised.com]
Sent: 06 August 2010 09:16
To: Jürgen Weichand
Cc: James Rapaport; jeroen.ticheler@anonymised.com; geonetwork-devel@anonymised.comeforge.net
Subject: Re: [GeoNetwork-devel] Related metadata selection - 2.6.0-RC0
Thanks Jürgen, fixed in trunk.
The issue reported by James, is another problem I think.
2010/8/6 Jürgen Weichand <juergen.weichand@anonymised.com>:
I've a similar problem with the CSW-Interface.
The name of the field in the Lucene-Index has changed from 2.4.3 --> 2.6.0
RC1 parentId --> parentUuid
Please fix the mapping in the config-csw.xml to the new fieldname.
<parameter name="ParentIdentifier"
field="parentId"type="SupportedISOQueryables">
Kind regards,
Juergen
James Rapaport schrieb:
I've been trying out the Related metadata selection / parentIdentifier
functionality in 2.6.0-RC0. When searching using the Related metadata
selection dialog, it seems that metadata instances based on sample templates
(e.g. Template for Raster data in ISO 19139) are found but metadata
instances based on my bespoke template (also ISO 19139) are not found.
The difference between the metadata instances, based on the two templates,
is large but I've checked that the metadata instance that was based on my
template is valid (both schema and Schematron) using an application outside
GeoNetwork. I can't see any other obvious differences outside the metadata
such as their privileges and so on.
When running parentIdentifier search for selection a default filter is
applied to search only for dataset
which is maybe not a good idea as parents may be a serie for example.
If you change your hierarchy level you should found your metadata
records.
I'll check that and fix the default filter.
Cheers.
Francois
The GeoNetwork instance is running on Tomcat 6 using PostgreSQL 8.4. I
compiled it from source using Eclipse Helios.
I would certainly find this particular functionality useful so I'd be
grateful if this issue could be resolved - or if anyone can suggest if I'm
going wrong somewhere.
Kind regards,
James
The Palm PDK Hot Apps Program offers developers who use the
Plug-In Development Kit to bring their C/C++ apps to Palm for a share
of $1 Million in cash or HP Products. Visit us here for more details:
http://p.sf.net/sfu/dev2dev-palm
GeoNetwork-devel mailing list
Jürgen Weichand
Landesamt für Vermessung und Geoinformation
- Betrieb GeodatenOnline, Schnittstellen zu Spezialanwendungen -
Alexandrastrasse 4
D-80538 München
Mail: Juergen.Weichand@anonymised.com
Web: http://www.geodaten.bayern.de
This SF.net email is sponsored by
Make an app they can't live without
Enter the BlackBerry Developer Challenge
http://p.sf.net/sfu/RIM-dev2dev
