I have a problem here…
I want to public my geonetwork so I can get a remoting access from Internet, but I have no clue what to do? I already conf de file server.xml as the post-installation said… we just can’t access to my server from other computer Intranet/Internet… we are using tomcat 5.5.2 and oracle as our DB…
I’ve already conf all geonetwork, Language, Colors, Banners etc… All I want is that someone else can access to my GeoNetwork Server and upload and download metadata…
some can help me…
Saludos…
Hi Khrizart,
Did you do all these checks, and where did it fail?
- Locally you can connect to Tomcat on port 8080? Using the IP address and the name?
- Locally you can connect to the GeoNetwork instance?
- Remotely you can connect to the Tomcat on port 8080?
if not, is there a firewall that prevents you to connect to a port 8080?
- Remotely you can connect to the GeoNetwork instance?
Ciao,
Jeroen
On Feb 5, 2007, at 1:38 AM, Khrizart wrote:
I have a problem here....
I want to public my geonetwork so I can get a remoting access from Internet, but I have no clue what to do? I already conf de file server.xml as the post-installation said.... we just can't access to my server from other computer Intranet/Internet... we are using tomcat 5.5.2 and oracle as our DB...
I've already conf all geonetwork, Language, Colors, Banners etc… All I want is that someone else can access to my GeoNetwork Server and upload and download metadata..
some can help me...
Saludos....
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-devel mailing list
Tnks… You save our world… we trough that the port 8080 was open, and never cross our minds to check it again… until today I read your answer… tks…
On 2/5/07, Jeroen Ticheler <Jeroen.Ticheler@anonymised.com> wrote:
Hi Khrizart,
8080?
Ciao,
Jeroen
some can help me…
Saludos…
security?
job easier.
Geronimo
projects/geonetwork
Saludos…
