[GeoNetwork-devel] Render action links when changing catalogue template
I noticed what seems to be a bug on Geonetwork. The thing is that when you load the catalogue, for each result a row of buttons with some action links is rendered. However, if you play around with the template buttons of the toolbar, and then you select back the FULL mode, this row of buttons is not loaded. I found out that this link buttons are not part of the FULL template, and they are built up after the results load.
So the question is, is there any workaround to trigger this link buttons initialization?
These are the buttons I am referring to:
César
Tracasa
