[GeoNetwork-devel] Request to become a committer on the geosource sandbox in SVN
Hi List,
For some background, I am working on the GeoSource project. The main goals of this project are documented here: http://n2.nabble.com/french-community…-tc1393262.html.
I have read, understood, and agree to the committer responsibilities and guidelines documented at http://trac.osgeo.org/geonetwork/wiki/committer.
May I be granted access as a committer to the geosource sandbox area?
My username is etaffoureau.
Etienne
P Pensez à l’environnement avant d’imprimer ce message
Think Environment before printing
Le contenu de ce mél et de ses pièces jointes est destiné à l’usage exclusif du (des) destinataire(s) désigné(s) comme tel(s).
En cas de réception par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L’absence de virus a été vérifiée à l’émission, il convient néanmoins de s’assurer de l’absence de contamination à sa réception.
The contents of this email and any attachments are confidential. They are intended for the named recipient(s) only.
If you have received this email in error please notify the system manager or the sender immediately and do not disclose the contents to
anyone or make copies.
eSafe scanned this email for viruses, vandals and malicious content.
Hi Etienne,
You’ve been granted access to work on that geosource sandbox. I understand that you have been working on Geosource for some time already, so you should be familiar with that code. Please make sure you are subscribed to mailing lists of GeoNetwork and to add yourself to the list on the WIKI.
http://trac.osgeo.org/geonetwork/wiki/committer_list
Ciao,
Jeroen
On Dec 18, 2008, at 10:05 AM, Taffoureau Etienne wrote:
Hi List,
Etienne
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can’t happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/_______________________________________________
GeoNetwork-devel mailing list
GeoNetwork-devel@anonymised.comourceforge.net
