[GeoNetwork-devel] RNDT profile and UUID generation
Hi list,
as already mentioned in a previous thread we're dealing with RNDT, an Italian
profile of ISO19139, and we have created a schema plugin for it here:
   http://github.com/geonetwork/schema-plugins/tree/master/iso19139.rndt
This profile puts some restrictions on the metadata fileIdentifier syntax and
some other internal ids.
Going into details, the fileIdentifier should be built using a fixed code
assigned to the source governative organization that creates the metadata, and
a dynamic part; the profile reccommends to use a timestamp for the dynamic
part, but it's not mandatory.
The solution implemented in the published schema plugin solves the issue of
creating the metadata ids using the update-fixed-info.xsl file, and setting as
true the readwriteUuid property of the schema.
The fixed code is stored as the geonetwork site uuid (that fits nicely in there,
and it's available in the various xsl transformation inside GN) and the UUID
generated by GN is used as the dynamic part.
So far, so good.
First question is: did you find any profile requiring particular constraints
such this in the creation of the UUIDs? How did you solve the problem?
I remember Francois had to do with a profile that needed to deal with the
resource identifier and the catalog URL
(http://sourceforge.net/p/geonetwork/mailman/message/31624545/).
Now we are trying to allow the creation of RNDT metadata for different
organizations inside a single GeoNetwork instance.
Note that the existing implementation, by storing the fixed prefix as the GN
site ID, only allows to create/edit metadata related to a single organization.
Allowing a multi-organization instance requires that a list of such fixed codes
should be stored somewhere else, and possibily externalized in some way.
The schema plugin architecture at the moment does not provide similar
functionalities.
Any work in progress, or plan, about improvements in schema plugin in this
direction?
   Emanuele
Our support, Your Success!
Visit http://opensdi.geo-solutions.it for more information.
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
Haven't had to do it yet but we have had one organisation that is/was considering have a parseable fileIdentifier here in AU.
So if I understand correctly, the problem sounds like it could be addressed using a related records approach like the following:
1. Having service metadata records for each site/catalogue with fileIdentifier (or an MD_Identifier) set to GeoNetwork site id (harvested between all sites that use this approach).
2. Allow the user to create a sibling or parentIdentifier relationship between their metadata record and a service metadata record of the organisation they want it associated with. (May need a bit of fiddling in the sibling/parentIdentifier related record handling stuff).
3. Update the fileIdentifier with the value of this sibling/parentIdentifier using your readWriteUuid solution when the record is saved (update-fixed-info.xsl) - if the sibling/parentidentifier isn't there then that means use the current catalogue site identifier as the association.
Would work for metadata records created and managed in GN but presumably that is the use case you're dealing with. This way you could use the existing stuff for this. (If I was doing it, I'd use service metadata records as siblings approach - see http://trac.osgeo.org/geonetwork/wiki/MetadataSiblings as that would leave parentIdentifier free for something else).
You could also do a thesaurus approach: keep site identifiers as term identifiers for organisation names in a thesaurus, allow the user to choose a term from your thesaurus when they edit a record for the first time, then copy the site identifier into the fileIdentifier using your readWriteUuid approach.
Maybe this is all too twisty but probably there are other ways to do this using the flexibility of GN :slight_smile:
Simon
________________________________________
Sent: Saturday, 29 March 2014 12:51 AM
To: Geonetwork devel lists
Subject: [GeoNetwork-devel] RNDT profile and UUID generation
Hi list,
   schema-plugins/iso19139.rndt at develop · geonetwork/schema-plugins · GitHub
So far, so good.
([GeoNetwork-devel] Metadata uuid creation | GeoNetwork - Geographic Metadata Catalog).
functionalities.
direction?
   Emanuele
Technical Lead
GeoNetwork-devel mailing list
Hi Simon,
thanks a lot, these are really interesting ideas.
   Ciao,
   Emanuele
association.
Simon
Hi list,
Italian profile of ISO19139, and we have created a schema plugin for it
here:
and some other internal ids.
and a dynamic part; the profile reccommends to use a timestamp for the
dynamic part, but it's not mandatory.
as true the readwriteUuid property of the schema.
there, and it's available in the various xsl transformation inside GN) and
the UUID generated by GN is used as the dynamic part.
So far, so good.
constraints such this in the creation of the UUIDs? How did you solve the
problem?
GN site ID, only allows to create/edit metadata related to a single
organization. Allowing a multi-organization instance requires that a list
of such fixed codes should be stored somewhere else, and possibily
externalized in some way. The schema plugin architecture at the moment
does not provide similar functionalities.
direction?
   Emanuele
Technical Lead
